Weatherproof case build
I've added the temp/humidity and photocell boards to the case.  Now we just need a solution to run these with the Android platform.
Humidity/temp sensor. A little black RTV on the o-ring and this unit will seal watertight, the o-ring is just thick enough to keep the pins from grounding on the case.
[Image: 048eef467baf41a5cf6e44057ec0e9a1.jpg]
A blob of clear silicone to protect the pins from shorting and adhering to the case.
Photocell at the right.
[Image: 39381ba260e40d478ecf0178e4511493.jpg]
Add a fine mesh screen between the humidity/temp sensor to keep the debris infiltration to a minimum, clear plastic on the photocell.
[Image: dbfe1ad2957a27fbe22032f807596ce2.jpg]
Mesh guard from the front; to keep the bits out
[Image: 989255f7e694c8edacbb22246b59ced3.jpg]
Glued to the case with silicone, sealed up and wired - ready to run.
[Image: c61446b933dea9b3f7e4dd682ad7e5f2.jpg]
A couple new, small penetrations for the case.
[Image: f5b56db0c3042bae9b09c9f6f223f77a.jpg]
Sent from my iPhone using Tapatalk
Weatherproof case build - by ltorsini - 08-14-2016, 09:19 PM
RE: Weatherproof case build - by montero65 - 08-16-2016, 09:12 AM
RE: Weatherproof case build - by ltorsini - 08-18-2016, 06:34 AM
RE: Weatherproof case build - by montero65 - 08-18-2016, 06:46 AM
RE: Weatherproof case build - by ltorsini - 08-22-2016, 08:31 AM
Weatherproof case build - by ltorsini - 09-04-2016, 08:20 AM
RE: Weatherproof case build - by KablammoNick - 10-02-2016, 09:53 PM
RE: Weatherproof case build - by ltorsini - 10-02-2016, 10:10 PM
RE: Weatherproof case build - by KablammoNick - 10-02-2016, 10:21 PM
RE: Weatherproof case build - by ltorsini - 10-02-2016, 10:49 PM
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 64,889 07-23-2020, 05:31 AM
Last Post: devendraraju
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 3,998 11-12-2019, 04:52 AM
Last Post: xalius
  playbox case ribbon cable too short pinoosh 7 12,444 02-22-2019, 03:24 AM
Last Post: GaryFunk
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 11,649 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 19,133 07-18-2017, 10:39 AM
  A case with active cooling for 1Gb pine64 ishwest 5 10,135 06-28-2017, 04:05 AM
Last Post: ishwest
  Lego Case Kiryu 67 89,928 03-30-2017, 11:36 AM
Last Post: Luke
  Acrylic case with Lipo Holder and 2 Tactile push button included killor 9 13,183 10-24-2016, 08:18 AM
Last Post: killor
  Pine64 Layer case modmypi 2 5,346 10-04-2016, 02:45 AM
Last Post: modmypi
  Playbox case orderable? schindlb 8 13,748 10-02-2016, 08:20 AM
Last Post: schindlb
