Power Off / Reset Buttons - DietPi
(08-11-2016, 07:18 PM)pfeerick Wrote:
(08-11-2016, 04:12 PM)casmiguefl Wrote:
(08-11-2016, 03:46 PM)xalius Wrote: Reset is just a hardwired hardware reset, the power button is wired to the PMIC (Power Management IC) and has the usual power-on, soft-off and hard-off function depending on how long you press it. The PMIC sends an interrupt to the A64 when the Power button is pressed and you can read/write registers on the PMIC to configure the behavior a bit. In linux the powerbutton is also a event device (think /dev/input/eventXXX) and you can watch for those events with a tool like evtest ... on my Ubuntu images with Mate Desktop the power button brings up the normal Reboot/Shutdown menu, so I guess they already wired up some udev rules for that...
For reference see:
http://files.pine64.org/doc/Pine%20A64%2...elease.pdf
http://files.pine64.org/doc/datasheet/pi...t_V1.0.pdf
Thank you very much for the clarification, I'll give that a look and luckily make it able to shutdown. Right now either of them does nothing at all!  Smile
It is indeed in the /dev/input/event1.
When the button is pressed, weird characters are written to it.
Any idea on how I can make it so when the button is pressed "init 0" command is executed? Total noob to udev rules Sad
This most might be of use. Be warned... my OS of choice is Debian, if that makes an difference.
Thank you very much!
That actually seems like it will work perfectly. Smile
RE: Power Off / Reset Buttons - DietPi - by casmiguefl - 08-12-2016, 05:28 PM
  Z-Wave - Full and Low Power Inclusion mode B34N 1 4,301 03-26-2017, 06:03 PM
Last Post: B34N
  Power Supply for Pine a64 (2GB) Pip19083 1 4,517 01-22-2017, 01:32 PM
Last Post: Luke
  Low power headless operation? rubenk 9 15,485 01-05-2017, 12:37 AM
Last Post: swinging
  Power switch circuit drewh 43 64,092 09-19-2016, 09:17 AM
Last Post: tampadave
  power Circuit polo 28 41,582 07-01-2016, 07:06 PM
Last Post: pfeerick
  Power over Ethernet (PoE) WLR 1 5,864 02-10-2016, 07:14 PM
  USB HDD Power eender 5 9,577 02-06-2016, 09:30 PM
Last Post: blktiger
