Power Off / Reset Buttons - DietPi
Hi!
My pine arrived a couple days ago. I'm loving this little beast.
I have a couple trigger buttons laying around and I'd like to use one for the power off and other for the reset but I have no idea if the system is actively listening to the circuit of both these buttons.
I tried them on and nothing. Any tips?
Currently running DietPi as the OS.
Thanks!
Reset is just a hardwired hardware reset, the power button is wired to the PMIC (Power Management IC) and has the usual power-on, soft-off and hard-off function depending on how long you press it. The PMIC sends an interrupt to the A64 when the Power button is pressed and you can read/write registers on the PMIC to configure the behavior a bit. In linux the powerbutton is also a event device (think /dev/input/eventXXX) and you can watch for those events with a tool like evtest ... on my Ubuntu images with Mate Desktop the power button brings up the normal Reboot/Shutdown menu, so I guess they already wired up some udev rules for that...
For reference see:
http://files.pine64.org/doc/Pine%20A64%2...elease.pdf
http://files.pine64.org/doc/datasheet/pi...t_V1.0.pdf
(08-11-2016, 03:46 PM)xalius Wrote: Reset is just a hardwired hardware reset, the power button is wired to the PMIC (Power Management IC) and has the usual power-on, soft-off and hard-off function depending on how long you press it. The PMIC sends an interrupt to the A64 when the Power button is pressed and you can read/write registers on the PMIC to configure the behavior a bit. In linux the powerbutton is also a event device (think /dev/input/eventXXX) and you can watch for those events with a tool like evtest ... on my Ubuntu images with Mate Desktop the power button brings up the normal Reboot/Shutdown menu, so I guess they already wired up some udev rules for that...
For reference see:
Thank you very much for the clarification, I'll give that a look and luckily make it able to shutdown. Right now either of them does nothing at all!  Smile
It is indeed in the /dev/input/event1.
When the button is pressed, weird characters are written to it.
Any idea on how I can make it so when the button is pressed "init 0" command is executed? Total noob to udev rules Sad
For reference see:
This most might be of use. Be warned... my OS of choice is Debian, if that makes an difference.
For reference see:
Thank you very much!
That actually seems like it will work perfectly. Smile
  Z-Wave - Full and Low Power Inclusion mode B34N 1 7,294 03-26-2017, 06:03 PM
Last Post: B34N
  Power Supply for Pine a64 (2GB) Pip19083 1 7,499 01-22-2017, 01:32 PM
Last Post: Luke
  Low power headless operation? rubenk 9 24,249 01-05-2017, 12:37 AM
Last Post: swinging
  Power switch circuit drewh 43 100,269 09-19-2016, 09:17 AM
Last Post: tampadave
  power Circuit polo 28 66,713 07-01-2016, 07:06 PM
Last Post: pfeerick
  Power over Ethernet (PoE) WLR 1 8,516 02-10-2016, 07:14 PM
  USB HDD Power eender 5 14,803 02-06-2016, 09:30 PM
Last Post: blktiger
