SD card burn img size problems
(09-21-2016, 03:06 AM)tkaiser Wrote:
(09-21-2016, 02:53 AM)Ghost Wrote: It would be great if we could edit each and every post where Win32DiskImager was mentioned here on the forum and substitute in Etcher instead, but I don't think that's possible.
I wouldn't do that since it will render posts absolutely useless (people reporting that they suffer from broken installations after using "Etcher" which is just the result of search/replace). You can't change the past anyway.
<Edit>
The two most important places to simply replace all occurences if Win32DiskImager with Etcher are pine wiki and instructions on pine64.pro
Haha, good point! Well, hopefully the Pine wiki and pine64.pro information can be updated soon.
SD card burn img size problems - by stephen0205 - 08-11-2016, 07:34 AM
RE: SD card burn img size problems - by Ghost - 08-11-2016, 11:21 AM
RE: SD card burn img size problems - by Ghost - 09-18-2016, 07:57 AM
RE: SD card burn img size problems - by tkaiser - 09-18-2016, 09:57 AM
RE: SD card burn img size problems - by tllim - 09-20-2016, 07:00 PM
RE: SD card burn img size problems - by tkaiser - 09-21-2016, 01:38 AM
RE: SD card burn img size problems - by Ghost - 09-21-2016, 02:16 AM
RE: SD card burn img size problems - by tkaiser - 09-21-2016, 02:28 AM
RE: SD card burn img size problems - by Ghost - 09-21-2016, 02:53 AM
RE: SD card burn img size problems - by tkaiser - 09-21-2016, 03:06 AM
RE: SD card burn img size problems - by Ghost - 09-21-2016, 06:39 AM
RE: SD card burn img size problems - by tkaiser - 09-22-2016, 03:55 AM
RE: SD card burn img size problems - by tkaiser - 09-22-2016, 06:28 AM
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,720 08-07-2022, 10:47 AM
Last Post: commiecam
  How to boot from SD card on pinebook pro linux123 3 6,140 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 4,502 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 4,413 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 6,510 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 214,264 03-03-2020, 11:34 PM
Last Post: siyatalerja
  eMMC card on adapter Malmgren 8 11,335 03-20-2018, 11:14 AM
Last Post: Malmgren
  corrupt microsd card after reboot maxpayne 6 10,165 02-08-2017, 05:42 PM
Last Post: maxpayne
  recommended micro sd card? Gustavo Woltmann 1 3,642 01-03-2017, 11:38 PM
Last Post: MarkHaysHarris777
  What is on the Micro SC card that came with the board? clawinus 1 3,712 11-03-2016, 02:33 PM
