Power light flashes on then nothing
(08-03-2016, 08:43 PM)pfeerick Wrote:
(08-03-2016, 02:05 AM)foxy82 Wrote: I haven't attached the power switch to the board so I'm just turning it on using the switch on the wall power outlet. I don't have a battery...do I need one?
I used the Android LCD image. Also in case it was the LCD pulling too much power for my power supply I detatched the LCD and tried both android image that isn't specfgically for the LCD screen and also the Debian image both showed the same although I didn't have a display connected to the HDMI. I assume the power light should still not go off even if you don't have a display connected...
No, you shouldn't need a battery, unless you want your pine64 to be mobile ;D
Since you also the debian nonLCD image, and the power light still went off, I suspect either the USB lead you're using is wimpy and the voltage is dropping too low, or the power supplies you're using just aren't up to the task. Unfortunately, most 5v power supplies are around 5v when not loaded, and at hte power supply. Add to that thin wires, and load them up, and the voltage can easily sag to v4.75 or lower, and things like the Pine64 and Raspberry pi get unhappy! Try and grab yourself a power supply like the one Mark recommended, or one of the ones Adafruit sells... And no, the power light certainly should go off if there's a valid image on the microSD, and enough power is provided, regardless of if you have a monitor connected or not.
So I got the power supply tried it - same result red light flashes on then goes off....
Anything else I can try?
Power light flashes on then nothing - by foxy82 - 08-02-2016, 09:40 AM
RE: Power light flashes on then nothing - by foxy82 - 08-04-2016, 12:55 PM
  New RockPro64 Power Up Problem enorbet2 7 5,146 10-28-2023, 12:08 PM
Last Post: dkebler
  Pinecil power Erincka 0 1,868 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 1,952 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 2,436 03-14-2021, 09:05 AM
Last Post: xalius
  PBP won't power. Charge light solid orange/red but turns off. cmicallef 15 12,539 03-12-2021, 07:08 PM
Last Post: cmicallef
  howto power hdd via usb3 on rockpro64 hanscees 2 5,125 06-17-2020, 02:00 AM
Last Post: hanscees
  User Screen Black After Changing Power Settings 0b51Gekko 2 4,800 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  5.25 V _ ... 2A Power USB Adapter Guest2000 4 7,147 02-12-2017, 09:34 PM
  Power Switch for Pine64 512MB Board MonarchOfLight 0 2,561 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
  Power Ribbon for LCD Display Plot 3 6,159 10-23-2016, 12:16 PM
Last Post: dkryder
