Power light flashes on then nothing
(08-02-2016, 09:51 AM)MarkHaysHarris777 Wrote: First, make sure that you are using this power supply from MCM.
Second, if you're powering on with the power switch make sure that the battery is plugged in or you WILL get the same results you are describing.
Third, only use the Android LCD image .   None of the other images support the LCD display.
Visit us live on the chat for tips, tricks, and live assistance... lots of great guys eager to help you.
Thanks for the response. Do you have a link to the power supply?
I haven't attached the power switch to the board so I'm just turning it on using the switch on the wall power outlet. I don't have a battery...do I need one?
I used the Android LCD image. Also in case it was the LCD pulling too much power for my power supply I detatched the LCD and tried both android image that isn't specfgically for the LCD screen and also the Debian image both showed the same although I didn't have a display connected to the HDMI. I assume the power light should still not go off even if you don't have a display connected...
Power light flashes on then nothing - by foxy82 - 08-02-2016, 09:40 AM
RE: Power light flashes on then nothing - by foxy82 - 08-03-2016, 02:05 AM
  New RockPro64 Power Up Problem enorbet2 7 5,145 10-28-2023, 12:08 PM
Last Post: dkebler
  Pinecil power Erincka 0 1,868 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 1,952 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 2,436 03-14-2021, 09:05 AM
Last Post: xalius
  PBP won't power. Charge light solid orange/red but turns off. cmicallef 15 12,538 03-12-2021, 07:08 PM
Last Post: cmicallef
  howto power hdd via usb3 on rockpro64 hanscees 2 5,125 06-17-2020, 02:00 AM
Last Post: hanscees
  User Screen Black After Changing Power Settings 0b51Gekko 2 4,800 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  5.25 V _ ... 2A Power USB Adapter Guest2000 4 7,147 02-12-2017, 09:34 PM
  Power Switch for Pine64 512MB Board MonarchOfLight 0 2,561 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
  Power Ribbon for LCD Display Plot 3 6,158 10-23-2016, 12:16 PM
Last Post: dkryder
