DeviceNotReady After flashing modem firmware
Just wanted to touch base back here for future readers.
The modem got stuck in Factory Test Mode after a failed flash which made getting into fastboot mode fail with most methods. After this I was able to recover the modem and then flash to the latest 0.7.4 release.
If you have one of these newer pinephone pros then be wary when flashing. Only do it manually following the documentation on the github. Always make sure you're in fastboot with lsusb before flashing any file.
If you run into issues, join the matrix room and you'll get sorted out
RE: DeviceNotReady After flashing modem firmware - by nekonosuke - 02-13-2024, 11:36 PM
  Pinephone(pro) modem bug / shortcomings MadameMalady 2 2,506 06-19-2023, 03:40 PM
Last Post: MadameMalady
  Flashing to the eMMC prairie33 4 2,712 06-18-2022, 04:49 PM
Last Post: fxc
  Modem turns off on suspend twzorek95 5 3,254 05-06-2022, 01:51 PM
Last Post: ertizpau
  How can one change eg25-g modem software? tckosvic 1 1,282 05-06-2022, 10:05 AM
Last Post: magdesign
  Modem unreliable on the PPP with Mobian EwigeBlumenkraft 2 1,860 03-17-2022, 02:11 AM
Last Post: EwigeBlumenkraft
  Explorer vs Dev edition - flashing? brb78 0 1,200 12-09-2021, 02:25 PM
Last Post: brb78
