Modem unreliable on the PPP with Mobian
I am using my Pinephone Pro EE since monday as a daily driver. Works good so far but since yesterday the modem began having hiccups.
Sometimes it shows no reception or the bar symbol is crossed out completely.
With mmcli I can see the modem in the first case but in the second it is not found.
I tried various combinations of mmcli scan and disable/enable with no result. Only restarting the phone works most of the time.
However when I restart the phone some settings (display zoom, input voltage from keyboard etc.) are gone.
Is there a reliable way to use modem manager to restore the connection?
What modem firmware are you running? Biktorg version with advised parameters works fine for me.
(03-17-2022, 01:58 AM)dukla2000 Wrote: What modem firmware are you running? Biktorg version with advised parameters works fine for me.
I am still on the stock firmware.
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 9 1,671 02-20-2024, 12:40 PM
Last Post: mburns
  DeviceNotReady After flashing modem firmware nekonosuke 4 670 02-13-2024, 11:36 PM
Last Post: nekonosuke
  Disable the GDM service in Mobian. mburns 0 455 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 865 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 488 11-07-2023, 10:01 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 686 11-07-2023, 09:44 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 588 10-14-2023, 11:57 AM
Last Post: mburns
  Mobian libnotify custom notifications MadameMalady 5 1,375 08-01-2023, 08:51 AM
Last Post: MadameMalady
  Mobian .desktop file creation MadameMalady 15 3,092 07-27-2023, 04:12 PM
  XFCE mobian running nicely but some oddities grump_fiddle_reinstall 0 795 07-01-2023, 08:18 AM
