PinePhone Pro Explorer's edition Qualcomm modem recovery
Hi guys,
i really need help on my PPPro. I was recently trying to update my modem's firmware using gnome-firmware app using this instruction in the video "4 of 5": https://forum.pine64.org/showthread.php?tid=18209
Update failed to install, and now i ended up with non-bootable modem. I searched the PineWiki and found this emergency procedure designed to boot modem in to EDL mode by shorting the test points on the PinePhone, but when i removed the back cover i only found there is no simmilar pins, or at least i don't know which ones to use on my the explorerss edition phone. Also i used this Hardware test build from here: https://wiki.pine64.org/wiki/PinePhone_P...e_Checking
and test fails for sim card. Also in Arch build it is not listed as /dev/ttyUSB2 or any ttyUSB. Seems it is bricked, and i need to enter EDL mode somehow. Is there any hope to revive the modem?
[Image: PPP-mainboard-nanosim-1.jpg]
PinePhone Pro Explorer's edition Qualcomm modem recovery - by shifras - 01-12-2024, 01:49 PM
  PinePhone Pro EDL boot by shorting contacts ozkenlc 1 135 05-01-2024, 09:29 AM
Last Post: traut
Thumbs Up Pinephone Pro + Keyboard for sale Jimmy88 2 817 04-22-2024, 08:38 PM
Last Post: AegisWages
  PinePhone only turns on sometimes zvavybir 1 426 03-27-2024, 12:19 PM
Last Post: zvavybir
  Failed firmware change for the Quectel EG25GGBR07A08M2G modem of PPP Explorer Edition andrey 1 408 02-17-2024, 12:32 PM
Last Post: traut
Question Screen turning off and booting problems with the Pinephone Pro xnZwJR6vys9a2wm7yWE4 0 244 01-16-2024, 02:38 PM
Last Post: xnZwJR6vys9a2wm7yWE4
  Pinephone Pro LCD and Touchscreen Hobgoblin 8 3,878 01-14-2024, 02:50 PM
Last Post: shifras
  Messed Up Modem dorkydev 13 1,834 12-23-2023, 03:02 PM
Last Post: dorkydev
  Recurrent problems with broken charger chip on the pinephone/pinephone pro keyboard Jite 4 1,214 11-18-2023, 07:25 AM
Last Post: crocspot
  Bypass contact points on PPP developer edition cyrelk 1 1,216 10-10-2023, 10:23 AM
Last Post: fxc
  is it possible to install a pinephone pro mainboard in a pinephone hannescam 7 2,732 08-13-2023, 04:50 AM
Last Post: fxc
