asking for CLI-friendly software recommendations
I'd prefer to stick with Mobian, because I'm most used to Debian-based distros (and Mobian seems like the closest available to vanilla Debian on Pinephone/Pinephone Pro). But I'm looking to switch as much of my computing as possible to the tty. What recommendations do you all have?
My progress so far, aside from the utilities that ship with bash (at least on Debian):
* nvlc - stream internet radio and play downloaded audio
* curl wttr.in - weather service
* tilde - yes, it's heresy not to use vim or emacs or nano, but tilde is a simple CUA text editor and gets out of my way
* elinks - read HTML webpages online (but doesn't look like a way to access web-based services that require logging in); it is easy to use and impressively snappy except when my internet is slow
* alpine - takes tinkering in the config file and browsing forums, but seems to be working now
* pdftoppm, cacaview - initial tests suggest that they can act as a minimally adequate pdf viewer together, with much zooming in
* mapscii.me - would not work online with telnet, but the local client over node.js works; if you don't have unicode, it's not quite as rich of an experience
* will experiment with apertium for machine translation and csound for synthesizing music
Holes in my environment:
* browsh, carbonyl - respectively based on Firefox and Chromium, they purport to bring more extensive and modern access to more complicated web services, and they render webpages relatively impressively, but after a complicated installation process they both appear to require a mouse to do anything beyond scrolling whichever page you initially requested (and they may have other holes), but my tty does not have touch or mouse support; so a big hole is any web-based services that I can't find some alternative for (dropbox for file backups, ecommerce, proprietary financial services, and anything else that needs login and/or interactivity even as simple as a forum or shipping carrier website)
* clocks - any way to set alarms from the terminal and have them wake the phone to go off; gnome-clocks's command line options are exceedingly limited
* ditto for any kind of calling or text messaging; command line options are exceedingly limited for gnome-calls and chatty; gnome-calls refuses to work without a graphical display; chatty does have an intriguing daemon option but no documentation in the man page about how to use it; emailing a text to myself did not work either (phonenumber@txt.att.net)
* and a big miscellaneous category for various services that i took for granted on the gui, for example turning the volume or brightness up and down, checking the statuses of battery or mobile data or wifi, anything to do with bluetooth, even turning the torch on or off - hopefully some searching around online can come up with commands at least for the things that also apply to desktop Debian
* not to even mention a zoom videochat client, which is the only reason I still keep an old Android phone lying around because zoom's desktop client appears to be for x86 only, and their web client wasn't picking up my camera or microphone even in GUI Firefox
asking for CLI-friendly software recommendations - by andrew907 - 11-11-2023, 09:20 AM
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 634 10-14-2023, 11:57 AM
Last Post: mburns
  Recommendations for... dorkydev 6 1,759 07-24-2023, 06:12 PM
Last Post: dorkydev
  How do I tell Phosh that my app is mobile friendly? Barugon 5 1,744 06-05-2023, 09:24 PM
Last Post: Barugon
  How can one change eg25-g modem software? tckosvic 1 1,278 05-06-2022, 10:05 AM
Last Post: magdesign
  Looking for app recommendations Riley 0 1,485 03-22-2022, 03:22 PM
Last Post: Riley
  Bluetooth sync software adamfowleruk 1 1,266 03-21-2022, 12:44 PM
