How do I tell Phosh that my app is mobile friendly?
I'm writing an app using egui but the launcher only shows up if I click "Show All Apps". How do I get the launcher to show up when only mobile friendly apps are shown?
looks like you need to add this to your .desktop file
X-Purism-FormFactor=Workstation;Mobile;
https://linmob.net/phosh-0-12-app-drawer/
(06-05-2023, 02:22 PM)tophneal Wrote: looks like you need to add this to your .desktop file
Thanks.
@tophneal
Do you happen to know how to prevent the on-screen keyboard from popping up when the app starts?
(06-05-2023, 02:33 PM)Barugon Wrote: Do you happen to know how to prevent the on-screen keyboard from popping up when the app starts?
I know you can disable the OSK through Settings > Accessibility, but I think that disabled it all together, probably not your use case of hiding the OSK when your app is started from the Phosh drawer(?)
(06-05-2023, 03:50 PM)tophneal Wrote: I know you can disable the OSK through Settings > Accessibility, but I think that disabled it all together, probably not your use case of hiding the OSK when your app is started from the Phosh drawer(?)
I don't want to completely disable the keyboard but for some reason, it pops up when my app starts. If I press the keyboard icon in the lower right to hide the keyboard, bring up the app drawer and then return to my app then the keyboard is back again.
Turns out that it's an issue with egui: https://github.com/emilk/egui/issues/3057
  [WIP] KDE Plasma Mobile 6.0 Builds & Ports dorkydev 5 685 04-15-2024, 08:08 AM
Last Post: u-kidjp
  Command lines to remove the Phosh UI dorkydev 1 328 02-12-2024, 11:56 AM
Last Post: nekonosuke
  Can't configure APN/Have no mobile internet zvavybir 4 885 11-22-2023, 12:11 AM
Last Post: zvavybir
  The Mobian Phosh Experience mburns 1 894 11-18-2023, 08:21 AM
Last Post: crocspot
  asking for CLI-friendly software recommendations andrew907 9 1,456 11-18-2023, 07:54 AM
Last Post: crocspot
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 608 10-14-2023, 11:57 AM
Last Post: mburns
  The Phosh Web app vs Angelfish mburns 0 656 06-19-2023, 11:57 AM
Last Post: mburns
  Manjaro Phosh - Tiny Blue Indicator Light - Blinking ArchiMark 2 953 06-11-2023, 04:12 PM
Last Post: ArchiMark
  Phosh Updating - Battery Charge Indicator - Jittery Settings - Display Usability ArchiMark 4 1,424 05-28-2023, 07:00 AM
  Plasma Mobile Taskbar / Navigation Bar is Missing & Upper Panel X0X0X0X0X0 1 1,320 11-24-2022, 07:19 AM
Last Post: mburns
