System won't suspend due to suspention notification
(09-24-2023, 03:52 AM)whackx Wrote:
(09-20-2023, 12:55 PM)user641 Wrote:
(09-19-2023, 05:26 AM)alaraajavamma Wrote:
(09-18-2023, 06:19 PM)user641 Wrote: so, this command turns off all notifications?
No it only disables ability to wake the screen (which will prevent suspend)
So you will still get sound and vibration. And calls and sms will still wake the screen.
I did that command, how to undo it if I want?
Also those are good features, but they eat the battery.
you can get the current list of settings via
gsettings get sm.puri.phosh.notifications wakeup-screen-triggers
So, in my case there was only one setting which was ['urgency'] . To set this option again you can execute the following command
gsettings set sm.puri.phosh.notifications wakeup-screen-triggers "['urgency']"
Thanks so much for the rich info.
RE: System won't suspend due to suspention notification - by user641 - 09-24-2023, 05:47 AM
  Errors when start the system kubussz 2 620 11-21-2023, 11:07 AM
Last Post: kubussz
  Unable to wake up from suspend xavi92 5 1,211 10-26-2023, 03:02 PM
Last Post: xavi92
  Suspend on ram user641 2 756 09-25-2023, 01:44 PM
Last Post: user641
  Power Consumption on Suspend JudgeFudge 8 1,936 07-29-2023, 06:24 AM
Last Post: JudgeFudge
  Chatty does not work after suspend mode user641 4 1,991 07-18-2023, 10:43 AM
Last Post: alaraajavamma
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,259 03-01-2023, 04:45 PM
Last Post: anonymous
  German Emergency Alarm System Test arno_nuehm 4 1,929 12-11-2022, 01:44 PM
Last Post: traut
  suspend inhibit no longer working jsch 3 2,043 10-23-2022, 09:20 AM
Last Post: LibrePhoneUser
  low disk space on file system root revisited benedikt55 2 1,541 09-24-2022, 10:16 AM
Last Post: benedikt55
  Pinephone incoming call / SMS notification no ringing / notification volume dcinoz 3 2,909 06-02-2022, 07:16 AM
Last Post: arkadione
