Phosh Updating - Battery Charge Indicator - Jittery Settings - Display Usability
Have Manjaro Phosh Beta 30 installed on PPP (with keyboard). Overall, works pretty good.
Have a few issues I would appreciate input on.
1. Phosh Updating
I see there is now Phosh Beta 32 available.
Do I need to update via new image file or can it be done using Pacman or ?
If can be done either way, is there advantage to doing it one way or the other?
2. Battery Charge Indicator
I use Keyboard unit with the PPP, what percentage  should I see next to battery icon? (100% or 200%)
3. Jittery Display - Settings
Most of the time, the display looks OK. However, when I try to change the display settings, the settings window is very jittery (jumpy looking). As a result, I can not change the display settings!
I have similar issue with changing setting preferences in Firefox browser and think it happened in some other situations.
Any way to fix thing this? This is a big problem in usability of PPP.
4. Display Usability
In some situations there is too much space above and below a window or app. This is really impacts usability of display when you use PPP with Keyboard and display is in landscape orientation.
Any ways to improve this?
Thank you for any and all input.
Mark
Phosh Updating - Battery Charge Indicator - Jittery Settings - Display Usability - by ArchiMark - 05-26-2023, 10:29 AM
  Command lines to remove the Phosh UI dorkydev 1 366 02-12-2024, 11:56 AM
Last Post: nekonosuke
  The Mobian Phosh Experience mburns 1 948 11-18-2023, 08:21 AM
Last Post: crocspot
  "failed to start simple desktop display manager" PinePhonePro / Plasma Beta15 RC4 OhMeadhbh 1 705 11-09-2023, 07:39 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 634 10-14-2023, 11:57 AM
Last Post: mburns
  Battery life thread: discussion, support and tips apink 6 2,166 09-22-2023, 02:37 PM
Last Post: tookmeayear
Sad Couple of problems updating Ctrl_Amiga_1070 12 2,918 08-19-2023, 05:12 PM
Last Post: Ctrl_Amiga_1070
  The Phosh Web app vs Angelfish mburns 0 677 06-19-2023, 11:57 AM
Last Post: mburns
  Manjaro Phosh - Tiny Blue Indicator Light - Blinking ArchiMark 2 987 06-11-2023, 04:12 PM
Last Post: ArchiMark
  How do I tell Phosh that my app is mobile friendly? Barugon 5 1,765 06-05-2023, 09:24 PM
Last Post: Barugon
  [Mobian] : Battery consumption and OS compatibility freelectro 2 1,128 06-02-2023, 06:55 AM
Last Post: Fred Zyphal
