PD resets during heat up tip [Pinecil V2]
Many time passed, but now seems issue is solved. I will share some my findings, can be useful for others, as officials are not active here.
What helps: updated FW to latest and change to another PD charger, another model.
During search a solution found some interesting information:
link - sometimes PD charger's IC can communicate with issues.
link - similar.
link - Pinecill needs PD charger with grounded core. Was old FW, I tried to ground my soldering iron as recomended, but this did not help. But stable work was achieved with another car PD charger connected to 12V battery. Also stable work was with original 65W PD charger with ground cord from my Lenovo laptop.
I would like to mention here, that most of the PD chargers have not ground core, they are wall chargers with 2 lines.
link - as we can see now, Pinecil is very dependent from type of PD charger conditions. Some PD chargers can refuse to support 20V PD mode for soldering iron, while they perfectly works with another devices.
In my case, I bought new cheap PD 65W GaN charger from Asometech at Aliexpress (6.08$), and it works fine with latest FW in Pinecill V2: link
Rolleyes
RE: PD resets during heat up tip [Pinecil V2] - by Neitron4ik - 10-09-2023, 01:22 AM
Question Can Pinecil Read USB-C Cable E-Marker Chips? Garywoo 0 133 04-23-2024, 01:48 PM
Last Post: Garywoo
  Connecting a power supply to the Pinecil jon_bondy 1 458 02-29-2024, 07:37 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 886 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 425 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 8,509 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 733 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,377 10-09-2023, 10:10 PM
Last Post: clemon79
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,530 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,331 12-14-2022, 01:03 AM
Last Post: River
  Survey on Pinecil Tips, Please fill out River 0 1,310 11-06-2022, 02:43 AM
Last Post: River
