Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold
Question
What is causing this and how can I fix it?
After an event which caused my Pinecil V2 to stop working with a near-0V 3V3 rail until i desoldered the shorted USB C PD chip, my temperature readings jump to over 400°C. I am suspecting a voltage spike from a dodgy PSU to be the cause of this event, though i am not certian. The jumpy temperature reading only happens when the iron is heating up, not while in standby/off mode.
From what I can tell from the schematic, documentation and sourcecode, the Pinecil switches between heating and using the heater as a dodgy thermocouple. I am suspecting that another component got affected by the event and either gets stuck or take a longer-than-usual time to switch or settle. I have tried swapping the OP-Amp that is responible for reading the tip voltage, but to no avail, so i swapped the original one back in. I am currently going through the sourcecode to try and increase the measuring time and/or the time waited after switching off the heater power and before measureing the temperature.
This seems promising so far: https://github.com/Ralim/IronOS/blob/993...Q.cpp#L154
Does anyone else have a different idea to what could be the cause of this issue?
Question Can Pinecil Read USB-C Cable E-Marker Chips? Garywoo 0 33 04-23-2024, 01:48 PM
Last Post: Garywoo
  Connecting a power supply to the Pinecil jon_bondy 1 391 02-29-2024, 07:37 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 802 01-31-2024, 12:34 AM
Last Post: suga7
  Asus laptop power supply can also power Pinecil biketool 9 8,324 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 675 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,306 10-09-2023, 10:10 PM
Last Post: clemon79
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,559 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,461 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,264 12-14-2022, 01:03 AM
Last Post: River
  Survey on Pinecil Tips, Please fill out River 0 1,266 11-06-2022, 02:43 AM
Last Post: River
