Pinecil v2 power cycles at higher voltages?
Question
Just got a v2, and love it. When I run it off of a 20w USB power supply at 9v (over USB-C) or 12v (with USB-C to DC), it runs fine. However, I have two USB power supplies that it can negotiate 20v with (with the DC cable, natch). One of them is a 100w, so it negotiates 20v/5a, and works fine. The other one is a 65w, so it negotiates 20v/3.25a, and once I hit the + to start it warming up, it blinks just for a second, power cycles, and dumps me back to the main menu.
Seeing as it runs fine negotiating 9v/2a on a 20w channel, and 20w/5a on a 100w channel, I'm not sure why it's choking on 20v/3.25a. This is on the latest stable IronOS firmware, v2.20, with no changes to default settings other than fast scrolling and blinking temp during cooldown. Any ideas?
(03-14-2023, 03:10 PM)clemon79 Wrote: Just got a v2, and love it. When I run it off of a 20w USB power supply at 9v (over USB-C) or 12v (with USB-C to DC), it runs fine. However, I have two USB power supplies that it can negotiate 20v with (with the DC cable, natch). One of them is a 100w, so it negotiates 20v/5a, and works fine. The other one is a 65w, so it negotiates 20v/3.25a, and once I hit the + to start it warming up, it blinks just for a second, power cycles, and dumps me back to the main menu.
Is your another unstable 20V PD charger Baseus brand name? If yes, try latest firmware in Pinecil. If doesnt help, use another PD charger.
I had similar issue, you can check my neighbored topic here.
(10-09-2023, 01:38 AM)Neitron4ik Wrote: Is your another unstable 20V PD charger Baseus brand name? If yes, try latest firmware in Pinecil.
It wasn't a Baseus, but many thanks, a firmware update fixed the issue, and it's working like a champ on 65w chargers now.
Question Can Pinecil Read USB-C Cable E-Marker Chips? Garywoo 0 32 04-23-2024, 01:48 PM
Last Post: Garywoo
  Connecting a power supply to the Pinecil jon_bondy 1 388 02-29-2024, 07:37 PM
Last Post: Okedokey
  Best power supply? naviathan 4 4,729 02-29-2024, 07:33 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 799 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 375 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 8,322 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 672 11-02-2023, 09:11 AM
Last Post: Harrysteed
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,557 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,461 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,264 12-14-2022, 01:03 AM
Last Post: River
