Metis package can't update
The metis package is coming from the AUR https://aur.archlinux.org/packages/metis
AUR packages use a file called a PKGBUILD which has instructions to build the package. In this case, the metis PKGBUILD has the line
arch=(x86_64)
meaning it only supports the x86_64 architecture.
If you want to build it you can try from the command line
sudo pamac build metis
Then when prompted press 'e' to edit the package build. You can edit the line above to
arch=(any)
then see how you go. You might need to make further changes to get the build to succeed on arm64.
Personally I would try to configure my update utility not to automatically upgrade from the AUR.
If you want to update just the pacman packages you can run
sudo pacman -Syu
Metis package can't update - by Mangustis - 02-06-2023, 10:18 AM
RE: Metis package can't update - by robocone - 02-22-2023, 03:23 PM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,333 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 1,073 09-16-2023, 09:41 AM
Last Post: jd50i
  invalid or corrupted package (PGP signature) Mangustis 0 804 02-21-2023, 04:50 PM
Last Post: Mangustis
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 3,385 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,441 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 2,133 05-10-2022, 01:52 AM
Last Post: diyagabriel
Big Grin Selling Pinbook Pro AND pinephone convergence package poltergiest 2 2,229 03-08-2022, 10:12 AM
Last Post: poltergiest
  Wont charge when powered off, and update question pineymousepad 7 6,067 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 1,402 11-18-2021, 06:37 PM
Last Post: reundo
Bug Wrong FN keys after keyboard FW update j4n3z 2 2,628 10-19-2021, 01:57 AM
Last Post: j4n3z
