Pinephone Pro Convergence Dock Ethernet performance with non-pro pinephone
(02-01-2023, 12:33 PM)Matt2020 Wrote: Hi,
New here.
I have a PinePhone (1.2, I think; definitely not Pro).  I also have the original convergence dock.
It works great, but the ethernet (verified with iperf3) is only getting 3-4M/s, where other devices on my network are at 1000M/s.  I know this old dock is only rated for 100M/s, but I was hoping to get closer to 100 than to 0 when using it!
Anyway, I'm considering buying the new one: https://pine64.com/product/pinephone-pro...cking-bar/
However, I don't want to do that if the performance is still going to be so poor.
Can anyone who has a non-Pro Pinephone and the new dock give me an idea of what their ethernet speed is?
Thanks!
i tested pinephone regular and 100Mbit/s usb-dock, and works quite near to 100Mbit/s.
could it be possible that you had other connections active at the same time, like mobile or wifi. pinephone's default routes may not go trivially. networkmanager may prioritize wifi over ethernet. basically, disable others.
RE: Pinephone Pro Convergence Dock Ethernet performance with non-pro pinephone - by zetabeta - 02-01-2023, 07:51 PM
  Case for Pinephone totilele 13 7,920 04-11-2024, 11:48 AM
Last Post: gramonyl
  PinePhone Dock with laptop? Mikey1977Y2J 2 718 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,372 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 494 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 569 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,101 10-20-2023, 04:11 PM
Last Post: mburns
  Convergence package USB-C Docking Bar for Wired Ethernet (part II) Peter Gamma 4 1,072 10-08-2023, 11:49 PM
Last Post: zetabeta
  Mouse for the PinePhone? Peter Gamma 21 15,869 10-04-2023, 10:24 AM
  PinePhone Wallet Case Shane 5 5,169 09-17-2023, 12:52 PM
Last Post: J T
  KB: Using bus powered USB peripherals with the pinephone keyboard mounted docsunset 9 38,375 08-07-2023, 06:12 AM
Last Post: mikeb
