Wifi adapter not found after update failed
I'm running postmarketOS on my Pinetab. Today I ran updates in "Software" (I know, I should have done this in the terminal).
The PineTab froze while the updates where running. After plenty of time I decided to do a hard reset.
I was happy when it booted normally after that. But then I realized, I had no wifi due to no wifi adapter had been found.
Is there a way to "get it back" or do I have to reflash the whole OS?
Thanks!
UPDATE:
I reflashed postmarketOS. That seemed much easier than messing around with that. I probably can delete this thread then...
Wifi adapter not found after update failed - by jojuma - 01-22-2023, 05:15 PM
  Pinetab 2 just arrived + when can hope to se wifi driver LRP 15 8,012 02-28-2024, 05:03 AM
Last Post: Surehand53
  Feeling Abandoned - No Official Forum Update Since March! Ptab2newb 2 1,058 09-27-2023, 12:14 PM
Last Post: Ptab2newb
  Pinetab2 without Wifi a comfort extra? Schlucker 8 3,198 07-14-2023, 03:09 AM
Last Post: gregb49
  PineTab2: How to fix "Package corrupted" error on update [SOLUTION] IPXFong 0 875 06-21-2023, 05:52 PM
Last Post: IPXFong
  No WiFi or Ethernet on vanilla PineTab 2 from the factory? SmittyWerbenyegermanjenson 6 2,349 06-06-2023, 05:26 PM
Last Post: fxc
  kernel crash on wifi initialization javier.pb 0 2,087 12-30-2020, 08:01 AM
Last Post: javier.pb
  WiFi signal weak kelbot 8 10,364 10-10-2020, 03:24 PM
Last Post: Jeffersoniantoo
