kernel crash on wifi initialization
I've been playing with the pinetab, in an attempt to get the u-boot startup shown in the screen, and in the way I've apparently broken the wifi/bt in kernel. The heading lines of the two cores are below. Out of those pieces, the system can be used with any extra problems.
What I've been doing basically was around u-boot, the pinetab specific device tree(s) and megous kernels (plus p-boot), and although all of them are potential causes, at this point my believing is that I might have done something on the wroing mmcblkX device, based on a comment on ubports boot.scr ("wifi takes /dev/mmcblk1").
Any ideas (or even trial solutions)
I've seen this on ubports on eMMC and mobian on SD (both previously working). Tried also to use content of linux-firmware from megous with no success (same than ones on ubports eMMC). At some point, I've been able to boot ubports with megous 5.10 kernel with same result.
Quote:WARNING: CPU: 3 PID: 295 at net/wireless/core.c:881 wiphy_register+0x950/0x970 [cfg80211]
Modules linked in: 8723cs(C+) snd_soc_simple_card(+) snd_soc_simple_card_utils axp20x_adc [...]
CPU: 3 PID: 295 Comm: systemd-udevd Tainted: G         C        5.9-sunxi64 #1
WARNING: CPU: 3 PID: 295 at drivers/staging/rtl8723cs/os_dep/linux/os_intfs.c:3695 rtw_os_ndevs_register+0xb4/0x110 [8723cs]
Modules linked in: 8723cs(C+) snd_soc_simple_card(+) snd_soc_simple_card_utils axp20x_adc ...]
CPU: 3 PID: 295 Comm: systemd-udevd Tainted: G        WC        5.9-sunxi64 #1
  Pinetab 2 just arrived + when can hope to se wifi driver LRP 15 7,812 02-28-2024, 05:03 AM
Last Post: Surehand53
  Pinetab2 without Wifi a comfort extra? Schlucker 8 3,119 07-14-2023, 03:09 AM
Last Post: gregb49
  No WiFi or Ethernet on vanilla PineTab 2 from the factory? SmittyWerbenyegermanjenson 6 2,304 06-06-2023, 05:26 PM
Last Post: fxc
  Wifi adapter not found after update failed jojuma 0 636 01-22-2023, 05:15 PM
Last Post: jojuma
  WiFi signal weak kelbot 8 10,300 10-10-2020, 03:24 PM
Last Post: Jeffersoniantoo
