Megapixels tuning
(02-06-2023, 04:01 PM)mburns Wrote:
(02-05-2023, 07:24 AM)irnemgk581 Wrote:
(01-30-2023, 11:40 AM)mburns Wrote: The Megapixels camera package requires libtiff5; libtiff6 leaves megapixels behind. I had to find libtiff.so.5.8.0 in a flatpack directory to install it alongside libtiff.so.6 and company. Manjaro Plasma has also regressed on other libraries required for megapixels. Media formats are a problem now.
Can you provide specific guidance on what you did in Mobian? I can't find this using flatpak, Megapixels won't open
I would type the following command line:
$find /usr -name "libtiff.so.5.8.0"
This needs to be copied to the same /usr/lib directory as where libtiff.so.6 is found. Cd to that directory and do the symbolic link from libtiff.so.5 to libtiff.so.5.8.0.
# ln -s libtiff.so.5.8.0 libtiff.so.5
I have a fresh version of the necessary changes to the config file for megapixels on the PinePhone Pro.
$ diff pine64,pinephone-pro.ini pine64,pinephone-pro.ini.sav
3c3
< model=PinePhone Pro
> model=PinePhone
18c18
< blacklevel=16
> blacklevel=3
21,24c21,24
< cropfactor=7.38
< fnumber=2.4
< iso-min=0
< iso-max=480
> cropfactor=10.81
> fnumber=2.2
> iso-min=100
> iso-max=64000
42,44c42
< mirrored=false
< blacklevel=3
< whitelevel=255
> mirrored=true
46c44
< cropfactor=9.48
> cropfactor=12.7
48,49d45
< iso-min=0
< iso-max=2047
this did not work at all
I didn't have a pine64,pinephone-pro.ini file and whenI just cut and pasted what you wrote, I got errors. Instead I did sudo nano and tried to create the file that wasn't there, then pasted this in. It also didn't work. It said model wasn't a valid key.
Then it added some lines in after I ran it with # in front of them. I just deleted everything and left the file there and I got a segmentation fault error.
Do I need to compile the megapixels that is on github or can I use the mobian megapixels?
A script for what to do would be great.
Megapixels tuning - by mburns - 12-12-2022, 07:51 PM
RE: Megapixels tuning - by mburns - 12-13-2022, 01:49 PM
RE: Megapixels tuning - by mburns - 12-14-2022, 11:04 AM
RE: Megapixels tuning - by mburns - 12-14-2022, 05:59 PM
RE: Megapixels tuning - by mburns - 12-17-2022, 12:35 AM
RE: Megapixels tuning - by mburns - 12-17-2022, 03:27 PM
RE: Megapixels tuning - by mburns - 01-12-2023, 08:05 AM
RE: Megapixels tuning - by mburns - 01-15-2023, 02:48 PM
RE: Megapixels tuning - by mburns - 01-30-2023, 11:40 AM
RE: Megapixels tuning - by irnemgk581 - 02-05-2023, 07:24 AM
RE: Megapixels tuning - by mburns - 02-06-2023, 04:01 PM
RE: Megapixels tuning - by username4 - 02-11-2023, 05:04 PM
RE: Megapixels tuning - by mburns - 02-12-2023, 11:57 AM
RE: Megapixels tuning - by pinephonepromobian - 02-16-2023, 07:33 PM
RE: Megapixels tuning - by Fish - 02-18-2023, 09:08 AM
RE: Megapixels tuning - by IHaveALinuxPhone - 02-16-2023, 03:47 PM
RE: Megapixels tuning - by mburns - 02-19-2023, 06:54 AM
RE: Megapixels tuning - by mburns - 03-01-2023, 05:25 PM
RE: Megapixels tuning - by mburns - 03-18-2023, 07:26 AM
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 791 11-07-2023, 09:44 AM
Last Post: mburns
  Megapixels on kernel > 5.19? timonoj 1 1,500 01-30-2023, 05:36 PM
Last Post: Piotr
  Megapixels (kernel 5.19) reports that a config file is missing. grump_fiddle_reinstall 2 1,956 11-30-2022, 07:44 AM
Last Post: mburns
  Megapixels - Camera App - Works w. Beta NOT Pro iwm 3 3,054 11-01-2022, 02:13 PM
Last Post: mburns
