Problems to Boot with Battery Only?
(07-20-2016, 12:46 PM)cantcode Wrote: Hi, I am having similar issues.
Running Debian, and when the blue battery (with 3 wires) is plugged in to the Pine board, Debian recognizes it's there. It calls it a laptop battery and even tells you the % charge the battery has.
That being said, I can't get the Pine to run with just the battery.
I have not soldered a power or reset switch to the board. (yet)
Try connecting the battery, and connecting either pins 5 (PWR/SB switch) and 9 (GND) on the EXP header together for a moment (or the two contracts nearest the edge of the board where the power switch is). The pine64 should start up and run fine then. If it doesn't, then I can't help you, as that is what my board does! :-O
Disclaimer: This is without the genuine battery, and the 10k (it was 10 wasn't it?) resistor trick on the middle pin to allow the pine to boot as I don't have a thermistor on my battery pack.
Problems to Boot with Battery Only? - by Evanidus - 07-15-2016, 11:33 AM
RE: Problems to Boot with Battery Only? - by pfeerick - 07-22-2016, 09:08 PM
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 198 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,264 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,701 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,604 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,727 08-07-2022, 10:47 AM
Last Post: commiecam
  How to boot from SD card on pinebook pro linux123 3 6,171 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,288 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,181 10-18-2020, 01:41 PM
Last Post: toiny
  SD Card boot - trying out OS Baconomics 1 4,430 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 6,532 03-18-2020, 09:42 AM
