PinePhone convergence docking bar malfunctioning
It can be either hardware or power supply to the dock.
Make sure the cable is plugged into a sufficient power supply wall plug.
Sometimes you may have to flip the USB C cable and then reattach.
You might find that it operates best when left alone. If you unplug and plug in elsewhere there may be some issues.
I have a total of three docks and two are Pine64 docks and they work fine however another Pine dock I had failed to operate at all.
I also have an additional dock by another company and it works reasonably well.
Somewhere in the comments there are power supply requirements listed out.
Also try unplugging other things in a wall outlet so the dock is the only item being power supplied.
Good luck.
TESTED: Arch Plasma, Arch Phosh , Manjaro Phosh, Manjaro Plasma
Fedora, Mobian, Postmarket Plasma, Postmarket Phosh, Kali, SXMO.
RE: PinePhone convergence docking bar malfunctioning - by Chief - 12-07-2022, 02:01 PM
  Case for Pinephone totilele 13 7,310 04-11-2024, 11:48 AM
Last Post: gramonyl
  PinePhone Dock with laptop? Mikey1977Y2J 2 645 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,211 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 457 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 525 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,028 10-20-2023, 04:11 PM
Last Post: mburns
  Convergence package USB-C Docking Bar for Wired Ethernet (part II) Peter Gamma 4 974 10-08-2023, 11:49 PM
Last Post: zetabeta
  Mouse for the PinePhone? Peter Gamma 21 15,463 10-04-2023, 10:24 AM
  PinePhone Wallet Case Shane 5 5,056 09-17-2023, 12:52 PM
Last Post: J T
  KB: Using bus powered USB peripherals with the pinephone keyboard mounted docsunset 9 37,565 08-07-2023, 06:12 AM
Last Post: mikeb
