Need to re-write U-boot from Pinephone pro currently in mass rom mode
(11-10-2022, 09:44 AM)wolverine1 Wrote: Hi fxc,
Thanks a lot for your reply. I tried this unsuccessfully. is it not possible to flash across to the U-boot memory directly ? Thanks
Hey wolverin1, U-Boot is the bootloader. It is part of the .img file you downloaded and flashed to the microSD card (or to the eMMC). If no bootloader on the eMMC or the microSD card is found it will boot into MaskROM mode. Because your phone boots into MaskROM mode we know that you do not have a correctly flashed microSD card inserted (or the card is inserted wrongly, such as the wrong slot or not all the way in - make sure the card is in the top slot). Once you get the card to boot you can simply overwrite the eMMC from there.
So your steps are:
1) Flash a microSD card correctly
2) Insert it into the phone, top slot and all the way
3) Boot the phone
4) Overwrite the eMMC
If the microSD card fails to boot then there is an error in step 1 or 2. I would suggest you to post the exact command and the exact filename of the image you used to flash the microSD card.
If you join the bridged community chat then you get very quick help: https://wiki.pine64.org/wiki/Main_Page#Chat_Platforms
RE: Need to re-write U-boot from Pinephone pro currently in mass rom mode - by fxc - 11-10-2022, 04:22 PM
  Pinephone pro replacement lcd screen Linuxuser3 0 240 04-27-2024, 05:42 AM
Last Post: Linuxuser3
Question Pinephone Pro for a Debian user? primesocial 2 316 04-15-2024, 03:01 AM
Last Post: zetabeta
  PinePhone Pro silver lining, it’s fast, real damn fast ashoka232 0 608 03-20-2024, 01:45 AM
Last Post: ashoka232
  PinePhone Pro Black Screen CrimsenRaven 2 511 03-16-2024, 11:40 AM
Last Post: tmoj
  PinePhone Pro Review tmoj 2 908 03-14-2024, 07:14 AM
Last Post: tmoj
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 844 02-17-2024, 04:04 AM
Last Post: fxc
Question Phone call with the pinephone pro dfs 5 4,454 02-10-2024, 09:54 PM
  Average Joe review of Pinephone Pro (March 2023) alaraajavamma 6 10,689 01-06-2024, 11:32 AM
Last Post: mikehenson
Question T-Mobile and Pinephone Pro in the US jydoxcen 4 998 01-02-2024, 09:08 AM
  Pinephone Pro Screen Protector jydoxcen 11 1,685 12-21-2023, 07:58 AM
Last Post: zetabeta
