GPIO on the RockPro64 - all pins high?
(11-01-2022, 10:13 AM)CounterPillow Wrote: That's because you didn't set a pull-down biasmode on the GPIOs, which by default I believe leaves them pulled up.
You can set them to pull-down bias with:
gpioset --bias=pull-down chipnum pinnum=value
There's probably also a way to set this from the device tree, but I don't know it off-hand.
In short, no, you didn't break anything.
Pin 6 should be an actual ground though, that's suspicious.
Hi, thanks for the help! I redid the wiring and tried your suggestion and now it's working!
What's odd is that connecting the LED to the GPIO GND in the circuit (ie the RockPro64's GND) works, but using the GND on my breadboard (connected to another microcontroller or a common ground, same thing) doesn't seem to work. I guess I'm missing something basic about GPIO or microcontrollers, which is maybe outside the scope of this board.
Thanks again!
RE: GPIO on the RockPro64 - all pins high? - by colinmarc - 11-18-2022, 10:20 AM
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,051 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 909 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,884 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 856 12-16-2022, 02:05 PM
Last Post: misterc
  ROCKPro64 DOA ajtravis 8 6,710 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 1,158 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 5,437 07-18-2022, 10:05 PM
Last Post: zer0sig
  RockPro64 premium aluminium casing justwantin 2 2,177 05-27-2022, 06:51 PM
Last Post: justwantin
  charging 3 rockpro64 from single source rpt312 1 1,754 05-16-2022, 02:34 AM
Last Post: dukla2000
  help or suggestions removing RockPro64 Playbox please? jahway603 2 2,402 03-22-2022, 12:17 PM
Last Post: jahway603
