Evolution no longer runs on Arch Phosh.
(10-17-2022, 04:06 AM)cone99 Wrote: I don't use Evolution, apart from installing it to use calendars with Radicale on my server.
I just tested setting and pulling events with the Calendar app on Phosh and all is working.
p.s. I should mention Evolution runs, just the UI is so tiny I didn't try doing anything with it!
Thanks for the response. I reflashed the device recently after the problem simply started after an update.
Never had this problem before at all. After checking into things decided to reflash it and used different options.
Still the same problem flashed it again normally answering yes to all changes - same problem.
As earlier stated I use plasma as well where this problem does not occur (same version) so for now
I will completely drop phosh until problem sorted out whatever that problem is.
TESTED: Arch Plasma, Arch Phosh , Manjaro Phosh, Manjaro Plasma
Fedora, Mobian, Postmarket Plasma, Postmarket Phosh, Kali, SXMO.
RE: Evolution no longer runs on Arch Phosh. - by Chief - 10-17-2022, 07:22 AM
  stuck between phosh and plasma aular 0 242 02-27-2024, 05:55 PM
Last Post: aular
  Updating Arch Linux _radv_ 8 878 02-20-2024, 09:35 AM
Last Post: _radv_
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 2 2,296 01-14-2024, 08:43 AM
Last Post: shifras
  How to install arch with FDE user641 3 818 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 1,984 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 2,889 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 932 07-29-2023, 08:27 AM
Last Post: alpineduck
  No keyboard on Arch Plasma when entering password on document Chief 0 857 12-03-2022, 08:35 PM
Last Post: Chief
  Curious About Arch Ferriah 2 2,168 11-07-2022, 04:38 PM
Last Post: Ferriah
  Latest version Arch Plasma looks good. Chief 5 2,476 10-23-2022, 01:53 PM
Last Post: Chief
