Scaling problem Arch Linux Phosh
(09-26-2022, 12:02 PM)mikehenson Wrote: I would like to know a way to keep the 150% scaling on reboot.
sudo nano /usr/share/phosh/phoc.ini
Note the values of "2" which are 200%.
Change that value to desired for example 1.5 (150%)
It can be 1.49 or 1.48 as the finest vales are adjusted too.
Ctrl O - then enter
Ctrl X - leaves editor.
On reboot the screen should be at 150% but instead the same bug occurs and it defaults to 200%
I suspect that a script is executed after the phoc.ini has been read and defaults. My guess.
TESTED: Arch Plasma, Arch Phosh , Manjaro Phosh, Manjaro Plasma
Fedora, Mobian, Postmarket Plasma, Postmarket Phosh, Kali, SXMO.
Scaling problem Arch Linux Phosh - by Chief - 09-25-2022, 05:44 PM
RE: Scaling problem Arch Linux Phosh - by cone99 - 09-26-2022, 05:49 AM
RE: Scaling problem Arch Linux Phosh - by Chief - 09-26-2022, 09:35 AM
RE: Scaling problem Arch Linux Phosh - by Chief - 09-26-2022, 12:34 PM
RE: Scaling problem Arch Linux Phosh - by Chief - 09-26-2022, 07:44 PM
RE: Scaling problem Arch Linux Phosh - by cone99 - 09-27-2022, 06:42 AM
RE: Scaling problem Arch Linux Phosh - by Chief - 09-27-2022, 12:31 PM
  stuck between phosh and plasma aular 0 253 02-27-2024, 05:55 PM
Last Post: aular
  Updating Arch Linux _radv_ 8 921 02-20-2024, 09:35 AM
Last Post: _radv_
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 2 2,341 01-14-2024, 08:43 AM
Last Post: shifras
  How to install arch with FDE user641 3 841 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 2,007 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 2,909 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 944 07-29-2023, 08:27 AM
Last Post: alpineduck
  No keyboard on Arch Plasma when entering password on document Chief 0 867 12-03-2022, 08:35 PM
Last Post: Chief
  Curious About Arch Ferriah 2 2,190 11-07-2022, 04:38 PM
Last Post: Ferriah
  Latest version Arch Plasma looks good. Chief 5 2,507 10-23-2022, 01:53 PM
Last Post: Chief
