Twister OS on PBP (2022)
Question
I have downloaded the TwisterOS image located here: Pinebook Pro Software Release - PINE64 and flashed it to a microSD on using DD under the included Manjaro Plasma installation. I followed the instructions and changed the armbianEnv.txt file to point at the rk3399-pinebook-pro.dtb file. I shutdown the computer and restarted with the card inserted (in the external microSD slot) and the machine will not post. The green power indicator slowly turns off and on in a continuous loop suggesting the machine is restarting after failing to boot.
Is this image not compatible with the latest release of the pinebook pro? Is there another version of the image I can/should use in its place? If this is all a moot point is there a similar flavor of linux to TwisterOS which includes wine and other arm specific versions of x86 emulation software?
Twister OS on PBP (2022) - by crusaderoath - 09-14-2022, 10:31 AM
RE: Twister OS on PBP (2022) - by KC9UDX - 09-15-2022, 04:25 AM
RE: Twister OS on PBP (2022) - by crusaderoath - 09-15-2022, 09:33 AM
RE: Twister OS on PBP (2022) - by steeb - 09-15-2022, 01:24 PM
RE: Twister OS on PBP (2022) - by KC9UDX - 09-15-2022, 04:33 PM
RE: Twister OS on PBP (2022) - by crusaderoath - 09-19-2022, 12:28 AM
RE: Twister OS on PBP (2022) - by wdt - 09-19-2022, 07:55 AM
RE: Twister OS on PBP (2022) - by KC9UDX - 09-22-2022, 08:33 AM
RE: Twister OS on PBP (2022) - by crusaderoath - 09-22-2022, 10:43 PM
RE: Twister OS on PBP (2022) - by wdt - 09-22-2022, 11:44 PM
  Manjaro PBP stable update 2022-06-19 bricked wpeckham 2 1,663 06-30-2022, 10:03 PM
Last Post: wangyukunshan
  bootloader menu to pick a kernel - what is the current situation in in early 2022? maxtothemax 4 3,155 02-05-2022, 03:04 PM
Last Post: maxtothemax
  Very Low Volume in Twister OS dennisfaucher 0 1,291 06-03-2021, 01:38 PM
Last Post: dennisfaucher
