Mobian bust again after dist-upgrade?
(09-16-2022, 04:57 AM)biketool Wrote:
(09-14-2022, 08:59 AM)Chief Wrote:
(09-13-2022, 02:15 AM)biketool Wrote: If you want to get back SMS you can install chatty but that knocks out gnome-contacts.  Not a big deal in my case as my gnome-contacts stopped working anyways.
So I am without evolution contacts now and am waiting to try to reinstall that, and hopefully someone posts a list of other stuff I did not notice getting uninstalled.
On Arch Linux Phosh Evolution works in accordance with Chatty no problems.
there is a version clash between special versions of software for Mobian and the Debian repositories along side.
For example whatever is needed for screen red-shifting for night is now missing too.
I will probably need to wipe and reinstall as the upgrade logs have probably been overwritten by now.
I see ... over time these things may be resolved but is certainly annoying when one must with it 'now'. I have tried several images but I have settled on one for sure because all mainly works and that's Arch Phosh. My second phone uses Postmarket Plasma and in my opinion it is the only Plasma version (24) that works half decently and certainly with Postmarket. I tried Mobian several times now over the past year and I noted that it was like one bug and then another type scenario. Like I said over time it will be sorted out I hope.
TESTED: Arch Plasma, Arch Phosh , Manjaro Phosh, Manjaro Plasma
Fedora, Mobian, Postmarket Plasma, Postmarket Phosh, Kali, SXMO.
RE: Mobian bust again after dist-upgrade? - by Chief - 09-16-2022, 05:27 PM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 16 2,326 04-28-2024, 01:52 AM
Last Post: diederik
  Disable the GDM service in Mobian. mburns 0 488 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 938 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 526 11-07-2023, 10:01 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 758 11-07-2023, 09:44 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 634 10-14-2023, 11:57 AM
Last Post: mburns
  Mobian libnotify custom notifications MadameMalady 5 1,467 08-01-2023, 08:51 AM
Last Post: MadameMalady
  Mobian .desktop file creation MadameMalady 15 3,372 07-27-2023, 04:12 PM
  XFCE mobian running nicely but some oddities grump_fiddle_reinstall 0 823 07-01-2023, 08:18 AM
  [Mobian] : Battery consumption and OS compatibility freelectro 2 1,124 06-02-2023, 06:55 AM
Last Post: Fred Zyphal
