Wifi issue since last update and held back updates
(09-08-2022, 03:35 AM)user641 Wrote:
(09-08-2022, 03:15 AM)goku499 Wrote: Hello,
I'm using Mobian bookworm since a long time now.
Since last update the Wifi has been broken and I can't connect to my AP. So I can't update.
Also I've had tons of held back package updates since a long time.
I'm thinking about reinstalling the whole OS from scratch but I would like to keep my data.
Do we have a guide on this?
Thank you.
I am having similar problems, my date was stucked at august 27th, I fixed with ntp but can't reach any website, including the debian and mobian repos. But my wifi works fine, I can run apt update && apt upgrade using tor
I Was having the exact same problem: after a recent update, wifi was on seemed to be connected, but there was no internet connectivity.
Luckily the solution in this thread worked for me: https://forum.pine64.org/showthread.php?tid=17288
RE: Wifi issue since last update and held back updates - by tcharlss - 09-10-2022, 01:38 PM
  New keyboard issue sandspur 29 13,273 10-05-2023, 02:27 AM
  packages held back user641 7 1,660 09-18-2023, 03:05 PM
Last Post: diederik
  No volume control after latest updates Zebulon Walton 19 7,637 09-08-2023, 08:28 AM
Last Post: jessencan
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,948 08-31-2023, 12:38 PM
Last Post: vusra
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 2,023 07-18-2023, 08:54 AM
Last Post: junelung
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 1,278 07-17-2023, 01:49 AM
Last Post: junelung
  how to update mobian over tor vusra 13 7,303 07-09-2023, 08:57 PM
Last Post: vusra
  Haven't seen updates in a while Zebulon Walton 3 1,369 06-24-2023, 04:29 PM
  Wifi doesn't work after update nickolas 2 1,330 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 1,448 03-17-2023, 07:26 AM
