rock64 totally brick
(09-02-2022, 05:18 PM)dakobg Wrote: Hi,
I do not have any idea what happen
I have several rock64 but one of them look like is brick!!!
I think the problem is with spi u-boot (or something else?!)
I try with different sd-carts different images including erase and flash u-boot-spi
Also I try to boot with shorting pins 25+23 or 25+21 and release after 2 -3 seconds after power is plugged .. this not help as well
I open a ticket to pine64 support .. they totally reject me .. short answer was .. check in the forum this is software issue they will help
At power-on all 3 lights are on + yellow on ethernet port
serial uart show .. nothing just from time to time no senses symbols (and yes I'm sure I use/connect correctly work with all other rock64 )
My quick question's
1. any idea
2. is there a way to try somehow to reflash rock64 ?! (look like I cannot do that for SPI only)
I think the problem can be something else not in spi .. also power adapter is ok for sure
I do not want to RIP this rock64 in the garbage since the situation with the chips is still terrible and will be waste of chips Smile   but if I do not have other options .. Sad
Did you ever get a solution to this?  I have a rock64 that behaves identically to what you're describing.  Seems totally dead and if I try to boot with just microSD and serial (and 23+25 jumpered) I can occasionally get a symbol on the serial port but nothing more
rock64 totally brick - by dakobg - 09-02-2022, 05:18 PM
RE: rock64 totally brick - by t4_4t - 09-02-2022, 07:10 PM
RE: rock64 totally brick - by olivercfc - 11-07-2022, 05:45 PM
  Are HW design files available for ROCK64? irenek 3 4,771 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 331 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,065 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 623 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,227 01-15-2023, 10:36 AM
Last Post: ds00
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,522 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,623 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,521 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 7,044 09-28-2021, 03:07 PM
Last Post: TRS-80
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 9 33,426 09-28-2021, 10:52 AM
Last Post: lewiscamron72
