rock64 totally brick
Disconnect all connections except power and serial console.
(If there is a connection to the USB-Port, disconnect that as well.)
1)  Disable SPI (shorting pins 25+23 or 25+21). (shorting pins 25+23 or 25+21)
2)  If eMMC is installed, disable it with a jumper pin.
In this state, write an image that has been confirmed to boot to the SD-CARD and boot.
(There is no need to remove the SPI jumper during the boot process.)
If you get a readable message on the serial console, you may be able to recover.
If, unfortunately, you get nothing at all from the serial console,
Try pressing the reset button several times, and the situation may change.
If there is no change in the situation after several tries, there is little hope of recovery.
rock64 totally brick - by dakobg - 09-02-2022, 05:18 PM
RE: rock64 totally brick - by t4_4t - 09-02-2022, 07:10 PM
RE: rock64 totally brick - by olivercfc - 11-07-2022, 05:45 PM
  Are HW design files available for ROCK64? irenek 3 4,950 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 345 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,094 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 635 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,315 01-15-2023, 10:36 AM
Last Post: ds00
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,548 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,653 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,618 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 7,091 09-28-2021, 03:07 PM
Last Post: TRS-80
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 9 33,516 09-28-2021, 10:52 AM
Last Post: lewiscamron72
