Battery Management
Using a python script to create a poc.
I could not find a setting to disable charging. Since pp draws more than 0.1A it's sufficient to set the current limit to 0.1A.
    'battery_current': {
        'filename': '/sys/class/power_supply/axp20x-battery/hwmon4/curr1_input',  # noqa E501
        'description': 'battery current in mA'},
    # 'battery_voltage': {
    #    'filename': '/sys/class/power_supply/axp20x-battery/hwmon4/in0_input',
    #    'description': 'battery voltage in mV'},
    'usb_current_limit': {
        'filename': '/sys/class/power_supply/axp20x-usb/input_current_limit',
        'description': 'usb current limit in µA'},
    'usb_charger_current_limit': {
        'filename': '/sys/class/power_supply/axp20x-usb/usb_dcp_input_current_limit',  # noqa E501
        'description': 'usb charger current limit in µA'},
    'battery_capacity': {
        'filename': '/sys/class/power_supply/axp20x-battery/capacity',
        'description': 'battery capacity in %'},
    'usb_charger_online': {
        'filename': '/sys/class/power_supply/axp20x-usb/online',
        'description': 'charger is online'},
Battery Management - by jsch - 07-26-2022, 01:33 PM
RE: Battery Management - by wibble - 07-27-2022, 02:21 AM
RE: Battery Management - by shulamy - 07-27-2022, 03:26 AM
RE: Battery Management - by vusra - 07-27-2022, 04:56 AM
RE: Battery Management - by jsch - 07-27-2022, 11:17 AM
  Battery problem with a Pinephone keyboard and Mobian elode 2 2,246 12-22-2022, 07:10 PM
Last Post: acid andy
  Possible solutions to the battery draining issue? 3x5co 5 2,489 11-28-2022, 10:58 AM
Last Post: 3x5co
  Will this battery-saving script cause problems? rp3 1 1,248 08-28-2022, 02:00 PM
  Limiting battery charging to some percentage TRS-80 3 3,269 08-22-2021, 01:02 AM
Last Post: bcnaz
  Increasing max voltage to use a bigger battery SocialNetworkingWasAMistake 4 3,989 06-09-2021, 09:59 AM
Last Post: wibble
  Possible fix for lousy standby battery life? bitnick 5 5,234 02-04-2021, 04:05 PM
Last Post: dcinoz
Sad battery usage HLing 3 4,639 08-29-2020, 06:04 AM
Last Post: User 18618
  CRUST power management on Mobian 0x070 6 8,814 07-16-2020, 04:30 AM
Last Post: a-wai
  SMS after dead battery antiX-Dave 4 6,098 06-05-2020, 08:11 PM
Last Post: antiX-Dave
  power management change? pjsf 1 3,451 06-05-2020, 05:16 PM
Last Post: a-wai
