Anyone yet received replacement sim/sd card holder
(06-10-2022, 12:10 PM)tckosvic Wrote:
(06-10-2022, 10:03 AM)Chief Wrote:
(06-10-2022, 07:44 AM)tckosvic Wrote:
(06-08-2022, 01:05 PM)Chief Wrote:
(06-08-2022, 08:07 AM)tckosvic Wrote: Thanks for repair info. You have much more patience than I.  I was so anxious to dump my 5 yr samsung android ASAP and get to a trackless environment with the PPP. that I put a big effort into trying OS/desktops and making adjustments with countless insertions of sd cards into the holder.  I added more than 125 messages to this forum when I was active.   I agree that it is a long way from a usable device; for me especially now that my sim card is not recognized as it once was.  I would buy a replacement motherboard if these were available to get around the sim card holder problem.  Last I looked, the PPP parts store only has 2 items in it; replacement pins and screws.  Big deal!
Simply stated - beta. I also took a chance and bought the device early based on the fact that my PP works great. All I was looking for from PPP was the speed. I still have a Blackberry Classic which is also a secure device hence why governments around the world have used Blackberry. Now that Blackberry has rolled over into Android my BBC is now a table time piece. My Moto E4 I use for images as required but it never leaves the house. From the very start all I have wanted for the past 25 years is a device that is secure and can handle documents. In my opinion only the Librem and PinePhone can handle that task. I'm willing to hang in there and continue with these devices. I think it's worth the wait.
Curious as to what OS/desktp combo you are using for PP.  Trying to avoid separate post asking this question in PP section of forum.
I use Lubuntu laptop and Arch linux PP
which desktop with arch.  Those available look to be: phosh, plasma, sxmo on the PP.
PP Arch Phosh. I just had a major issue with PP. For the first time I had to reflash EMMc with Arch phosh 2022-05 version. I just finished an hour ago. It seems tobe the last update which was settings and Uboot. I believe the Uboot update may have been faulty? My device kept shutting off by itself. Sound familiar (PPP before towboot). Resolved and now no more updates.
RE: Anyone yet received replacement sim/sd card holder - by Chief - 06-10-2022, 04:41 PM
Photo My PinePhone Pro does not read the micro SD card at all. tux_life 7 2,701 03-26-2023, 02:55 AM
Last Post: tux_life
  PinePhone Pro Motherboard with sim card holder tckosvic 1 1,630 08-22-2022, 06:42 PM
  Warning!!- sim card adapter destroyed my sim card holder on my pine phone pro ANDROID2468 11 7,686 06-15-2022, 02:32 AM
Last Post: fxc
  Replace PPP sim card/sd card slot hardware tckosvic 5 4,152 03-13-2022, 12:20 PM
Last Post: tckosvic
  How to remove the sim card liberty1234 6 4,313 02-16-2022, 01:27 PM
Last Post: ragreenburg
  SD Card insertion depth nristen 4 3,028 02-03-2022, 01:27 PM
Last Post: nristen
  Bent SD card pin bhboyle 5 3,526 02-03-2022, 09:54 AM
Last Post: kqlnut
  SD card slot specs frimmel 3 2,790 01-27-2022, 09:48 PM
Last Post: bcnaz
