Pinebook Pro Dock - cannot connect to monitor
(05-28-2022, 12:30 AM)Dominik Wrote:
(05-27-2022, 05:27 PM)lot378 Wrote: Just to throw out some random ideas to try:
  • Turn the cable between dock and PBP 180 degrees
  • Try a different HDMI cable
  • Try a different laptop?
It could be your dock is broken from new however thinking up and trying out different tests could be helpful.
What other functions on the dock actually seem to work?
What O/S and version is on the PBP?
What does the message log say? Does it mention the monitor?
If the message log shows the monitor is connected then have you tried manual commands to enable video to the monitor?
I'm on "5.17.5-4-MANJARO-ARM" (latest update). Tried to turn the cable, as well as the command recommended in the wiki. But, no effect on the connection. Manual commands I tried: "fn F7", also without effect. Will try your other advices (different cable, laptop and other functions) and document the results here.
The protocol I determine is (with pinephone pro)
- Disconnect all usbc (integrated cable, pd charging cable)
- Reboot your pineX
- Connect your pineX in the rigth way.
- Wait for screen sharing detection
- connect the power to the PD usbc dock port.
for me it is sharing screen but not negociating pinephone Amps more than 500mA
running echo 2000000 | sudo tee /sys/class/power_supply/rk818-usb/input_current_limit permits me to chage the phone and share screen at the same time
RE: Pinebook Pro Dock - cannot connect to monitor - by Rosbeefandino - 06-12-2022, 10:53 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 537 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 337 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 281 02-17-2024, 07:06 PM
  Pine Dock Networking Issue trillobite 1 265 02-10-2024, 12:03 AM
Last Post: trillobite
  Pinebook Pro charging issues tomekdev 1 614 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,082 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 130,138 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,004 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,417 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 135,695 11-30-2022, 04:28 PM
