Pinebook Pro Dock - cannot connect to monitor
(05-27-2022, 05:27 PM)lot378 Wrote: Just to throw out some random ideas to try:
  • Turn the cable between dock and PBP 180 degrees
  • Try a different HDMI cable
  • Try a different laptop?
It could be your dock is broken from new however thinking up and trying out different tests could be helpful.
What other functions on the dock actually seem to work?
What O/S and version is on the PBP?
What does the message log say? Does it mention the monitor?
If the message log shows the monitor is connected then have you tried manual commands to enable video to the monitor?
I'm on "5.17.5-4-MANJARO-ARM" (latest update). Tried to turn the cable, as well as the command recommended in the wiki. But, no effect on the connection. Manual commands I tried: "fn F7", also without effect. Will try your other advices (different cable, laptop and other functions) and document the results here.
RE: Pinebook Pro Dock - cannot connect to monitor - by Dominik - 05-28-2022, 12:30 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 700 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 372 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 318 02-17-2024, 07:06 PM
  Pine Dock Networking Issue trillobite 1 302 02-10-2024, 12:03 AM
Last Post: trillobite
  Pinebook Pro charging issues tomekdev 1 658 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,163 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,463 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,113 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,543 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 137,894 11-30-2022, 04:28 PM
