MMS via Verizon quit working
I've got an PinePhone (Evergreen) running Mobian Bookworm.  I got MMS messaging working in February after installing chatty v0.6.0-1 and it was fine until on or shortly before March 12 2022.  The messages seem to be retrieved and queued in ~/.mms/modemmanager/ but they don't get processed further and make their way into chatty anymore.
I've also got a Ting SIM with service via T-Mobile/Dish and MMS works fine with that.  I've switched SIMS back-and forth several times and the symptoms are persistent - Verizon always fails now and Ting works.
Here is the log for a 2nd attempt at processing a message:
May 18 15:09:09 pine mmsdtng[5933]: ../src/service.c:process_request_queue() service 0x55ab13be70
May 18 15:09:09 pine mmsdtng[5933]: ../src/service.c:process_request_queue() location http://63.55.64.151/servlets/mms?message-id=2105824508BB00007650000201
May 18 15:09:09 pine mmsdtng[5933]: ../src/service.c:resolve_host() No active proxy
May 18 15:09:09 pine mmsdtng[5933]: ../src/service.c:resolve_host_systemd() resolve_host_systemd
May 18 15:09:09 pine mmsdtng[5933]: ../src/service.c:resolve_host_systemd() systemd-resolved host ip: 63.55.64.151
May 18 15:09:09 pine mmsdtng[5933]: ../src/service.c:resolve_host() Using URI for request: http://63.55.64.151/servlets/mms?message-id=2105824508BB00007650000201
May 18 15:09:09 pine mmsdtng[5933]: ../src/service.c:create_new_web_message() host: 63.55.64.151, port: -1
May 18 15:09:09 pine mmsdtng[5933]: GSocketClient: Starting new address enumeration
May 18 15:09:09 pine mmsdtng[5933]: GSocketClient: Address enumeration succeeded
May 18 15:09:09 pine mmsdtng[5933]: GSocketClient: Starting TCP connection attempt
May 18 15:09:09 pine mmsdtng[5933]: ../src/service.c:soupmessage_network_event_cb() Socket 11 Binding to wwx0225d3683889 length 15
May 18 15:09:09 pine mmsdtng[5933]: ../src/service.c:soupmessage_network_event_cb() Socket is bound to wwx0225d3683889
May 18 15:09:10 pine mmsdtng[5933]: GSocketClient: TCP connection successful
May 18 15:09:10 pine mmsdtng[5933]: GSocketClient: Starting application layer connection
May 18 15:09:10 pine mmsdtng[5933]: GSocketClient: Connection successful!
May 18 15:10:10 pine mmsdtng[5933]: Fail to get data (http status = 007)
May 18 15:10:10 pine mmsdtng[5933]: ../src/service.c:on_message_done() status: 007
May 18 15:10:10 pine mmsdtng[5933]: ../src/service.c:on_message_done() data size = 0
May 18 15:10:10 pine mmsdtng[5933]: ../src/service.c:on_message_done() request->result_cb=0x557625fdc0 vs. retrieve_conf=0x557625fdc0/send_conf=0x557625a180/notify_resp=0x557625cf64
May 18 15:10:10 pine mmsdtng[5933]: ../src/service.c:on_message_done() On attempt 2
May 18 15:10:10 pine mmsdtng[5933]: ../src/service.c:on_message_done() Requeued Message
May 18 15:10:14 pine mmsdtng[5933]: ../src/service.c:service_retry_process_request_queue() Retrying Queue
After the "Connection successful!" message there should be some communication happening but instead I seem to get a timeout after one minute.  My MMS config has CarrierMMSC=http://mms.vtext.com/servlets/mms  and  MMS_APN=vzwinternet.
I've tried a varety of config changes in case this had something to do with DNS, and cleared nftables rules in case the firewall was interfering.  No joy.
Does anyone have a clue what's going on here?  Is there anyone for whom MMS & Verizon is working?
Edit 1: I have done regular dist-upgrades, including a couple days ago, and the symptoms don't seem to change.
MMS via Verizon quit working - by treebeard - 05-18-2022, 03:06 PM
RE: MMS via Verizon quit working - by cjhead - 05-20-2022, 10:34 AM
RE: MMS via Verizon quit working - by treebeard - 05-20-2022, 09:29 PM
RE: MMS via Verizon quit working - by treebeard - 06-04-2022, 03:43 PM
RE: MMS via Verizon quit working - by cjhead - 05-21-2022, 12:22 PM
  Mobile internet via cellular network mostly not working Anna 18 10,584 01-19-2024, 02:59 AM
Last Post: anonymous
Exclamation The internal speaker stops working anonymous 6 1,142 01-17-2024, 05:53 PM
  APN settings not working with new operator SIM card user641 1 1,069 03-01-2023, 04:43 PM
  Possible Solution for Microphone Not Working Ferriah 0 977 02-13-2023, 01:09 PM
Last Post: Ferriah
  Squeekboard stopped working Zebulon Walton 2 1,228 11-24-2022, 08:41 PM
  suspend inhibit no longer working jsch 3 2,051 10-23-2022, 09:20 AM
Last Post: LibrePhoneUser
  Rescue Your Mobian post Update Aug22 faster fix to working guide biketool 9 4,895 09-05-2022, 12:10 AM
  How to get Pinetime working with Pinephone arkadione 12 7,557 08-28-2022, 12:30 PM
Last Post: Fish
  Receiving SMS stopped working treebeard 11 5,700 08-12-2022, 10:31 AM
Last Post: treebeard
  PP keyboard not working at all jojuma 3 1,845 08-03-2022, 10:02 AM
Last Post: jojuma
