likely bug, volte does not work when operator side data blockage is activated
likely bug, volte does not work when operator side data blockage is activated.
for these i assume lte only mode. my o.s. is manjaro/phosh with 30.004.30.004 firmware.
because i have mi max 3 with custom android, which is based on android 11, i know that volte works with my operator regardless of is data on or off and both software button and operator side data blockage. (however, it could be possible that my operator has some issue with implementaion of volte and data block).
i tested my pinephone, if operator data blockage is activated, then volte does not work on pinephone. this is regardless, is software button data on or off. volte works if operator blockage is deactivated, and this is also regardless when software data on or off.
i have played with at commands and making calls with command line, my guess starting to be that bug is in the eg25-g chip.
how to i continue and where i report this?
likely bug, volte does not work when operator side data blockage is activated - by zetabeta - 05-05-2022, 07:59 AM
  4G VoLTE calls confirmed working with carrier x dcinoz 15 12,053 03-09-2024, 11:38 PM
Last Post: dcinoz
  pinephone with lte-m chip and volte zetabeta 0 676 10-02-2023, 05:42 AM
Last Post: zetabeta
  how to backup user data? Uturn 1 692 08-30-2023, 05:23 AM
  New Zealand network providers mobile data Linux2thabone 3 3,313 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 4,280 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  PureTalk work with Pinephone? car46999 6 2,952 01-30-2023, 12:05 AM
Last Post: car46999
  My screen bottom side has loosed its tactile function arbocenc 1 835 01-06-2023, 10:02 AM
Last Post: britelite
  cell data and MMS on AT+T prepaid ossands 2 1,483 10-13-2022, 07:28 AM
Last Post: ossands
Question Mobile data suddenly gone epiii2 1 1,357 05-23-2022, 04:57 PM
Last Post: epiii2
  No data access on ATT prepaid but my plan has data dc2daylight 6 4,730 04-03-2022, 02:14 PM
Last Post: dc2daylight
