Power issue with the Pro
(04-20-2022, 08:09 AM)Freitag Wrote:
(04-18-2022, 11:38 PM)Tim_D Wrote: Tim,
If I understand, and I apologize if no -I am an insomniac, so sometimes my mind doesn't function as well as I would like, you are seeing the same battery drain issue. Is it only occurring during the update process, or all the time? Were you able to update from the terminal (sudo pacman -Syyu)? I noted above, I was able to update this way, but still get a message about offline updates not occurring, and the option to repair/update. I have a half dozen other projects I am working, so the PPP is languishing. None of this really gets you the answer you want, contact details for whomever is fronting the Pro's bug fix, for lack of a better term, program. Again, apologies, I don't have better answers for you.
I know that there is an issue with the battery recharging as it should. I also am aware of an update that is meant to stop gap the issue. I've downloaded the file ~722kB for an 8 GB mmc. I've yet to install it. I'm moving glacially slow due to the fact that currently my ONLY internet is through my phone! It's sadly been that way for a LONG TIME and shows no likely change on the horizon.
Tim,
Understood.I will suggest the update via the terminal/pacman, if you haven't.
[/quote]
 Here's my current "catch", I'm having an impossible time having a keyboard AND the command line AT THE SAME TIME. I'm HEAVILY tempted to try reinstall the eMMC! I don't have it set up to boot up off a SD card. Frankly, I'm PERFECTLY content with it booting from the eMMC.
P.S.
I want to add, I don't mind the command line one bit. It's why I noticed the ABSENT man files! That was a SHOCKER to me!
 Like computing && Like Linux == good people
Power issue with the Pro - by Freitag - 04-05-2022, 03:43 PM
RE: Pro, potentially bricked, at a loss (a question for a question?) - by Tim_D - 04-23-2022, 11:04 PM
RE: Power issue with the Pro - by LPIZ - 04-25-2022, 06:14 AM
  Tow-Boot issue Barugon 1 1,377 10-22-2022, 03:22 AM
Last Post: AndrewBlackmiller
  Would disabling all cpu's except one save power on the PPP? rp3 3 2,015 08-27-2022, 01:10 AM
Last Post: uzanto
  Guide to power off the Pinephone Pro on low battery Ulfnic 5 3,778 02-11-2022, 02:47 PM
Last Post: dexy
  Battery charging issue kileel 1 1,773 12-13-2021, 03:58 PM
Last Post: kileel
