Battery charging issue
I got my PPP yesterday and have gotten postmarketOS to boot. Wifi works, I haven't tested much else though as battery support in pmOS is not complete.
One issue I'm really struggling with: I cannot get the battery charged. The device seems to bootloop into either pmOS if my SD card is installed or do nothing with just the nuked AOSP image (to be expected of course). The device tries to boot as soon as I plug it in, and the resulting power draw seems to drain what little charge the battery has managed to take in. I'm going to try with a different battery charged in my regular pinephone, but powering on when plugging it in seems like a firmware bug or at least a feature I can't seem to turn off. Am I doing something wrong?
I did some cursory digging through the devicetree power subsystem to see if I could turn up anything about why pmOS doesn't seem to detect the battery, but couldn't. I will get some more time to look at it tomorrow.
So part of this problem is the kernel being shipped with pmOS. After talking with Megi on discord, switching to Arch, which has his newer kernel 5.16-rc3, seemed to ameliorate this problem.
  PinePhone Pro battery life at the beginning of 2023? dante404 14 8,450 06-03-2023, 07:45 AM
Last Post: crocspot
  Charging woes Barugon 2 1,006 05-26-2023, 10:23 PM
Last Post: Barugon
  Unofficial Pinephone Battery Case lllsondowlll 15 15,333 02-21-2023, 10:34 AM
Last Post: Yaky
  Tow-Boot issue Barugon 1 1,348 10-22-2022, 03:22 AM
Last Post: AndrewBlackmiller
  QI charging back cover kmsgli 0 740 05-22-2022, 05:42 AM
Last Post: kmsgli
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 7 5,925 05-21-2022, 01:24 PM
Last Post: 98cwitr
  Battery Life is it possible?? Tech Question (sort of) scrwbigtek 4 3,277 05-11-2022, 06:01 AM
Last Post: danimations
  Power issue with the Pro Freitag 13 6,519 04-25-2022, 06:14 AM
Last Post: LPIZ
  Less than 12 hours on battery - doing nothing tcoulon 8 4,831 04-23-2022, 02:00 AM
Last Post: fxc
  Pinephone Battery doesn't fit in the Pinephone Pro ragreenburg 2 1,736 03-25-2022, 09:21 AM
Last Post: ragreenburg
