Power issue with the Pro
Tim,
If I understand, and I apologize if no -I am an insomniac, so sometimes my mind doesn't function as well as I would like, you are seeing the same battery drain issue. Is it only occurring during the update process, or all the time? Were you able to update from the terminal (sudo pacman -Syyu)? I noted above, I was able to update this way, but still get a message about offline updates not occurring, and the option to repair/update. I have a half dozen other projects I am working, so the PPP is languishing. None of this really gets you the answer you want, contact details for whomever is fronting the Pro's bug fix, for lack of a better term, program. Again, apologies, I don't have better answers for you.
[/quote]
I know that there is an issue with the battery recharging as it should. I also am aware of an update that is meant to stop gap the issue. I've downloaded the file ~722kB for an 8 GB mmc. I've yet to install it. I'm moving glacially slow due to the fact that currently my ONLY internet is through my phone! It's sadly been that way for a LONG TIME and shows no likely change on the horizon.
 Like computing && Like Linux == good people
Power issue with the Pro - by Freitag - 04-05-2022, 03:43 PM
RE: Pro, potentially bricked, at a loss (a question for a question?) - by Tim_D - 04-18-2022, 11:38 PM
RE: Power issue with the Pro - by LPIZ - 04-25-2022, 06:14 AM
  Tow-Boot issue Barugon 1 1,395 10-22-2022, 03:22 AM
Last Post: AndrewBlackmiller
  Would disabling all cpu's except one save power on the PPP? rp3 3 2,058 08-27-2022, 01:10 AM
Last Post: uzanto
  Guide to power off the Pinephone Pro on low battery Ulfnic 5 3,836 02-11-2022, 02:47 PM
Last Post: dexy
  Battery charging issue kileel 1 1,786 12-13-2021, 03:58 PM
Last Post: kileel
