no boot white led flashing
I came in to do a post on similar behavior, but I might as well attach it to this.
This has now happened with two different boards, and 2 5a PSUs, with two 8g EMMCs purchased from Pine.  And two factory heatsinks with pads.
It has happened with both Armbian server and desktop, and DietPi, which is the same kernel as Armbian.
The behavior is that everything installs and runs fine. I put Emby or Jellyfin on them, they scan the libraries. Everything is fine.
Then they randomly shut off, or actually I have no idea what happens. The screen goes black. The white LED stops flashing. The SSH session dies. Green light stays on.
Then they will sometimes, seemingly randomly, reboot successfully.  Everything is fine. No errors in the boot text.
Then the same thing. Screen is on, but black.  No white flashing LED.  Reboot does the same.
Oh and the first board, which is totally dark now, did the same thing with a brand new SD card.  Set it all up, rebooted. No white LED and black screen.
It's screwy.
NOTE: I HAVE TO PUT THIS ON HOLD AS DEFINITIVE OF THE PROBLEM.
It could be that it was a coincidence that the EMMC and SD card both failed in the same way. I don't know. I reburned the second EMMC, and it did seem to shut off on me once, but since I plugged it back in, and make sure the socket was all the way deep in, it seems like it is not failing after several reboots. Could it possibly be that I just was not seating the plug in deep enough? I don't know. But I did take the working EMMC off of the working board and put it on the board that was dead dead, and it booted again just fine, and now has continued to reboot. So I just burned an EMMC that I had from Hardkernel, which are the same, and it booted the other board fine.
I have yet to see if it quits again. But unless someone has seen this specific thing, I would just put it on hold for now as to ideas on how to tackle it. Thanks. Smile
no boot white led flashing - by moserwi - 03-27-2022, 07:36 AM
RE: no boot white led flashing - by Rocklobster - 03-27-2022, 06:14 PM
RE: no boot white led flashing - by moserwi - 03-28-2022, 02:19 PM
RE: no boot white led flashing - by Rocklobster - 03-28-2022, 07:26 PM
RE: no boot white led flashing - by mlohdael - 03-26-2023, 08:11 AM
RE: no boot white led flashing - by RocknKiosks - 04-27-2023, 05:23 PM
RE: no boot white led flashing - by RocknKiosks - 04-29-2023, 07:38 PM
RE: no boot white led flashing - by wdt - 05-18-2023, 10:46 AM
  enble boot after power loss/restore dkebler 18 9,815 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 122,206 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 722 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 4,381 07-14-2023, 08:59 AM
Last Post: rockjonn
  u-boot locked on pine64pro ljones 1 1,600 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,494 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 1,181 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 2,869 07-02-2022, 09:24 AM
Last Post: dkebler
  ROCKPRO64 PCI SSD SD-boot Install pspgarret 0 1,191 06-09-2022, 10:56 AM
Last Post: pspgarret
  RockPro64 has no white led, nor will it boot past... AnjinMeili 2 2,043 05-31-2022, 09:19 AM
Last Post: Rocklobster
