Play Store stops running every time
(07-06-2016, 04:30 AM)Luke Wrote: Have you tried what Danja suggested in this thread ?
For your convenience I will quote here "For the hell of it I tried to add my account again with the old one still there to see if it wasn't registering properly and would duplicate, it gave me the error as it should that it was already added and then I re-tried the play store and it worked."
That was one of the first things I tried even though it was for the authentication issue rather than the crash situation (unless they're just different manifestations of the same thing, IDK). It didn't help, tho. It may be that using Firefox to access the play store will be the way to go--I've been able to DL a couple of apps that way, though even that route isn't a guarantee of success. Somewhere along the DL/install process, play store is apparently called to finish the job and that's where it sometimes works, sometimes not.
My ultimate goal is to get Google Play Movies to play its own videos. I have 4 that I own and none of them play on the Pine with Android (nor Debian, for that matter). This is a different issue, I know, but it's therapeutic to blow off.
Thanks for quoting that thread for me. It was very thoughtful!
Lee
(07-05-2016, 10:00 PM)Artyom Wrote:
(07-05-2016, 10:25 AM)scdbeebe Wrote: I've had the same issue. My only workaround has been to go to play.google.com using Chrome and download whatever app I need from there.
Hi. I have same problem on Pine64 2G board. I solved this problem by removing the updates from Google Play service. If need i can add screenshot where.
I'll try that. I go into Settings/Apps to do that, yes?
RE: Play Store stops running every time - by Luke - 07-06-2016, 04:30 AM
RE: Play Store stops running every time - by thehamguy1 - 07-06-2016, 07:02 AM
  Issues with SD Card and Running Android Twistedx 0 3,596 02-26-2019, 11:58 AM
Last Post: Twistedx
  GPIO access running Android rddragon888 20 29,454 11-06-2017, 07:18 AM
Last Post: Anvesh Reddy
Question Running VPN Punkyclown 2 3,831 06-12-2017, 03:25 AM
Last Post: nicosaturno
  Pine A64 running Android 7.1 kernel panic leon 1 3,550 05-12-2017, 04:53 PM
Last Post: ayufan
  How to Make a Pine with Android 7.0 Stay on All the Time? Bob123456789 3 5,179 04-05-2017, 01:12 PM
Last Post: Bob123456789
Thumbs Up Kids love to Play Super Why App Erica Edwards 3 4,695 01-09-2017, 07:35 PM
  Play music won't play anything mikey0000 12 15,738 10-21-2016, 01:24 PM
Last Post: gezora
  ssh into Pine64 running Android scarabus 5 8,519 10-03-2016, 09:02 AM
Last Post: lovenemesis
  play store auth issue chrwei 29 32,668 09-09-2016, 11:02 AM
Last Post: eldaria
  Can't download apps off Google Play! Bacon Strips 6 8,677 08-31-2016, 12:26 PM
Last Post: DonFL
