ssh into Pine64 running Android
I can easily ssh into my Pine64 running Ubuntu, but I'm going around in circles trying to figure out how to do it under Android.
Is there a HOWTO anywhere?
Being able to ssh into Android is contrary to the design principles of Android.
... that said, it has always been possible to ssh into an Android phone; first by rooting it, and second by placing an sshd (ssh daemon) on the device like dropbear, or similar. Android was designed to have a locked-down linux kernel, and a java virtual machine layer over that (Dalvik) to run apps. It was not designed to work like a standard gnu+linux computer (although with rooting, dropbear, and busybox it can be made to work like any other gnu+linux device).
I would recommend you experiment with the rooted android image; then check out 'dropbear' and 'busybox'.
There are many on-line resources available to help in this area, and there is a huge droid community to help as well.
marcushh777
It is possible to use the rooted image, and an sshd server like 'dropbear' for android, as well the 'busybox' suiteof gnu+linux like tools.
Experiment with the rooted android image.  Also, find 'dropbear' on the Play Store, as well the 'busybox'.
marcushh777
Shy
I have posted to this topic twice... they have vanished... not sure where the posts are.
marcus
(07-24-2016, 08:58 PM)scarabus Wrote: I can easily ssh into my Pine64 running Ubuntu, but I'm going around in circles trying to figure out how to do it under Android.
You will need root and a 3rd parts SSH server Installed as android used adb as default
Or check out "Termux" if you don't want to roo the PINE64
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 389,334 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,782 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,873 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,002 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,080 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,630 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,352 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 259,177 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,558 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,444 02-10-2019, 07:44 PM
Last Post: mmmarcus
