Manjaro with Full Disk Encryption and GRUB
(02-11-2022, 04:21 PM)dumetrulo Wrote: Hi folks! I have a working install of Manjaro Sway on eMMC (and Tow-Boot on SPI), and want to 'reform' it into a setup with full FDE (as much as possible). To do this, I did the following so far:
  • Created a USB drive with one ESP and one LUKS partition
  • Created LVM swap and root partitions inside LUKS volume
  • Copied working system from eMMC to USB drive
  • Used manjaro-chroot to install GRUB
This USB drive can now boot from GRUB, and prompts for the LUKS password. After entering it, it takes about 3 minutes to unlock the key, then drops me at the GRUB prompt. It appears that there are no menu entries at all.
Any ideas on how to continue? And on a related note, any ideas on how to speed up the cores in GRUB so that it unlocks the key faster?
I think  if you have a TPM (Trusted Platform Module) chip on your system, you might be able to configure it to store the encryption key, which can speed up the unlocking process.
RE: Manjaro with Full Disk Encryption and GRUB - by frankkinney - 02-02-2024, 02:45 AM
  Manjaro Sway Theme Broken Eighty8 1 301 03-08-2024, 08:41 AM
  Manjaro network problem late 2023 acruhl 1 351 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,181 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,263 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 426 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 919 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,032 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,995 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 783 08-18-2023, 02:06 AM
Last Post: juliamenendez
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 988 08-18-2023, 01:58 AM
