Pinecil Power Supply with Removable Cables Recommendations
Hello everyone, I am in quite a pickle, as unlike the majority here, I live in a country (Israel) where despite the Europlug standard being officially supported, the socket (SI32) provides absolutely no structural support (as in, weight) for it, which is the cause of many power supplies with broken integrated Europlug plugs. This has caused me to be unable to actually utilize my Pinecil, since the only power supply I have for it is a 65W slim Lenovo charger, which while it has a removable plug cable (a shame that it is not grounded), unfortunately it's USB-C cable is a nonremovable PVC cable, rather than a Silicon cable.
Obviously, the solution would be to get a Framework charger... except that they are not yet available in Israel, and it would take too long until they start being available.
So does anyone have any recommendations for a charger that has a modular plug cable (2-pin is alright, however I'd rather have it 3-pin (such as the "Mickey Mouse" connector), so as to allow for grounding between the wall and the power supply) and either has a silicon cable (USB-C or DC552) or a USB-C socket for proper modularity and is not prohibitively expensive?
Pinecil Power Supply with Removable Cables Recommendations - by moriel5 - 02-06-2022, 01:30 PM
Question Can Pinecil Read USB-C Cable E-Marker Chips? Garywoo 0 87 04-23-2024, 01:48 PM
Last Post: Garywoo
  Connecting a power supply to the Pinecil jon_bondy 1 419 02-29-2024, 07:37 PM
Last Post: Okedokey
  Best power supply? naviathan 4 4,777 02-29-2024, 07:33 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 831 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 401 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 8,387 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 704 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,344 10-09-2023, 10:10 PM
Last Post: clemon79
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,601 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,496 02-02-2023, 11:45 AM
Last Post: VaZso
