MIPI-CSI IMX214 on Linux NO SUCCESS
(02-04-2022, 02:11 AM)zeus666 Wrote: we have a couple rockpro64 in service for computer vision tasks. However we use USB connected cameras, since back then there was no support for the MIPI interface.
For our new project we want to move the imx214 sensors over the MIPI-CSI interface. Here is where the trouble starts:
However, no video device is showing up - we tried different device trees from the rock64 repos on github all leading to no video devices.
We also tried manjaro arm, dietpi bullseye, dietpi buster and also manully updating the kernel.
Make sure you are clear whether you're talking about Rock64 or RockPro64 as those are different devices. I'm assuming you meant RockPro64 (even though this is the Rock64 sub-forum).
The issue likely stems from the kernel version and kernel configuration.
As you mentioned (didn't verify) the VIDEO_ROCKCHIP_ISP1 came out of staging in kernel 5.11. That means it's likely pointless to try a Bullseye (5.10) or even a Buster (4.19) based kernel. This is assuming that dietpi uses the same (kernel) version as Debian. I have no idea about manjaro.
Debian's Bookworm will ship with a 6.1 kernel and it has CONFIG_PHY_ROCKCHIP_INNO_CSIDPHY enabled as module.
However CONFIG_VIDEO_IMX214 is not enabled, which you quite likely need too.
I do not know if you need more kernel modules, but I'm pretty sure you need at least those 2.
MIPI-CSI IMX214 on Linux NO SUCCESS - by zeus666 - 02-04-2022, 02:11 AM
RE: MIPI-CSI IMX214 on Linux NO SUCCESS - by diederik - 06-02-2023, 07:52 AM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 173 03-24-2024, 01:07 PM
  Linux 5.15 Kernel - openSuse mark1250 0 1,306 12-02-2021, 04:36 PM
Last Post: mark1250
  Alpine Linux isndw 12 18,030 08-12-2021, 05:41 PM
Last Post: pix
Lightbulb RK3399 Linux rtl8822cu module bluetooth not working shivarj89 0 1,376 07-29-2021, 07:19 AM
Last Post: shivarj89
Information Linux Mainline ayufan 63 93,460 05-14-2021, 10:41 AM
Last Post: Wizzard
  Linux Images (ROCK64) pineadmin 164 283,876 02-12-2021, 10:14 AM
Last Post: useful64
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 12,442 08-31-2020, 01:41 AM
Last Post: as365n4
  Arch Linux ARM on the Rock64 V3 justinweiss 2 4,942 08-24-2020, 05:16 PM
Last Post: justinweiss
  Arch Linux Arm - external RTC problem max 1 3,012 08-17-2020, 10:35 AM
Last Post: max
Sad Is there a none-headless Linux OS that really works now for Rock64? AkiraSensei 7 9,691 07-09-2020, 10:02 PM
Last Post: nethammer
