Can I recover bricked device from Mask ROM mode?
(02-01-2022, 10:55 AM)Damage Wrote: Thanks @Ulfnic  and @Conjada and @ojimek.
I have wiped the eMMC and it now boots directly from SD card.
For another day (and thread) trying to install stock build on eMMC as a default, with SD card to try options - I wanted to put the stock back as the best chance to check the hardware (still can't get camera to work, or audio out to BT, or close apps that are open on many alternatives).
Brilliant!!
If you dont mind me asking did the "hold Re and insert power" do it or did you need to follow my instructions and "remove the battery&power, hold power button, put battery back, then hold Re and insert power"?
RE: Can I recover bricked device from Mask ROM mode? - by Ulfnic - 02-04-2022, 03:05 AM
  Shutdown / Reboot PPP from TowBoot "Volume Up" USB Readable Drive Mode crocspot 2 715 11-19-2023, 09:08 AM
Last Post: DaForest
  PPP now used as main device. DaForest 3 1,191 11-18-2023, 07:21 AM
Last Post: crocspot
  PPP as daily device. DaForest 5 1,319 11-05-2023, 10:00 AM
Last Post: DaForest
  PPP as daily device Chief 5 3,513 04-23-2023, 09:53 PM
Last Post: dcc
  Need to re-write U-boot from Pinephone pro currently in mass rom mode wolverine1 6 2,984 11-20-2022, 05:58 AM
Last Post: wibble
  completely bricked? rmpek 7 4,557 03-04-2022, 02:45 AM
Last Post: fxc
  New Pinephone Pro won't boot, not even in recovery mode Kaiser958 21 13,709 03-02-2022, 04:40 AM
Last Post: bcnaz
  How to activate developer mode on PPP explorer tckosvic 2 2,070 02-14-2022, 10:30 AM
Last Post: tckosvic
  Phone bricked after update. Won't boot mando 5 3,877 02-13-2022, 02:33 AM
Last Post: bcnaz
