Pinephone pro seems to have died overnight....
(01-28-2022, 10:14 PM)projectcato Wrote:
(01-28-2022, 06:27 PM)projectcato Wrote: Received my Explorer Edition yesterday. Booted it, played around. Everything seemed fine, Discover seemed broken (default KDE Manjaro). Shut it down, tried mounting it in the pinephone keyboard, never got the keyboard working, planned on trying the pogo shim this weekend. Shut it down, back into "phone mode" played around some more. Let it charge, then unplugged it and left it on my desk for the night.
This morning, wouldn't start. Plugged in, off to work. Still no boot. Removed battery, monkeyed around with various attempts at powering up. I don't get a vibration or anything on plugging it in as described charging indicator (pine64.org) .
Next steps for troubleshooting?
I didn't notice this before: PinePhone Pro - PINE64 (blue box):
Quote:If the battery is fully drained U-Boot might fail to boot any installed operating system on the eMMC and microSD card due to a bug.
If that's the case please start your phone in Maskrom mode and let it charge in that for a few hours. To do that:
  • Remove any microSD card from the phone
  • Hold the "RE" button underneath the back cover of your Explorer Edition (or shorting the bypass contact points on the Developer Edition)
  • Connect the phone to an USB port of a computer, while still holding the button
  • Check if the phone in Maskrom mode appears in the output of the Linux command
    lsusb
     on the computer (if the device disappears again please use a different cable)
  • Let the phone charge for multiple hours.
Can confirm this worked for me, got up to about ~30% charge by the time I got impatient and tested. Note, after this procedure, the phone only booted after another battery remove / reinstall.
I've tried this process doggedly and repeatedly, using various cables, etc., but still have a dead PPP.
Any other suggestions?
RE: Pinephone pro seems to have died overnight.... - by thismarty - 01-30-2022, 12:13 PM
Thumbs Up Pinephone Pro + Keyboard for sale Jimmy88 2 760 04-22-2024, 08:38 PM
Last Post: AegisWages
  PinePhone only turns on sometimes zvavybir 1 393 03-27-2024, 12:19 PM
Last Post: zvavybir
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 7 1,146 03-24-2024, 02:22 PM
Last Post: zetabeta
Question Screen turning off and booting problems with the Pinephone Pro xnZwJR6vys9a2wm7yWE4 0 225 01-16-2024, 02:38 PM
Last Post: xnZwJR6vys9a2wm7yWE4
  Pinephone Pro LCD and Touchscreen Hobgoblin 8 3,805 01-14-2024, 02:50 PM
Last Post: shifras
  Recurrent problems with broken charger chip on the pinephone/pinephone pro keyboard Jite 4 1,176 11-18-2023, 07:25 AM
Last Post: crocspot
  is it possible to install a pinephone pro mainboard in a pinephone hannescam 7 2,670 08-13-2023, 04:50 AM
Last Post: fxc
  Pinephone pro packet injection for internal wifi chipset covar 1 813 08-13-2023, 04:40 AM
Last Post: fxc
  PinePhone Keyboard won't work. read_kb_reg(PPKB_SYS_CONFIG) needs what? jovval 0 519 07-09-2023, 09:03 PM
Last Post: jovval
Photo My PinePhone Pro does not read the micro SD card at all. tux_life 7 2,658 03-26-2023, 02:55 AM
Last Post: tux_life
