Wifi doesn't respond
(01-31-2022, 02:28 AM)bcnaz Wrote:
(01-30-2022, 03:18 AM)jmlich Wrote: I can see at https://images.mobian-project.org/pinephone/ only this version or weekly builds.
Is that version unstable? I just wanted to try if wifi does work in other distros. I can try also weekly build of mobian if it helps. What logs should I attach?
I have NEVER had any wifi problems using Mobian ever,   --> even when it was still called Debian the wifi worked.
Then it should work with mobian, but it doesn't
(01-30-2022, 02:21 PM)j_s Wrote: Have you tried the multi-distro SD card image?
https://xnux.eu/p-boot-demo/
Will that change something?
I have made yet another test with factory image. See attached picture.
Wifi doesn't respond - by jmlich - 01-28-2022, 02:12 AM
RE: Wifi doesn't respond - by bcnaz - 01-28-2022, 11:47 PM
RE: Wifi doesn't respond - by jmlich - 01-30-2022, 03:18 AM
RE: Wifi doesn't respond - by bcnaz - 01-31-2022, 02:28 AM
RE: Wifi doesn't respond - by jmlich - 02-04-2022, 11:48 AM
RE: Wifi doesn't respond - by j_s - 01-30-2022, 02:21 PM
RE: Wifi doesn't respond - by bcnaz - 02-04-2022, 06:50 PM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 607 02-17-2024, 04:15 PM
Last Post: vortex
  bluetooth wifi bugs aular 6 1,615 08-27-2023, 07:53 AM
Last Post: aular
  No wifi/bluetooth on multiple OS's Xxancap15 1 1,169 10-28-2022, 12:10 PM
Last Post: fxc
  Wifi no scan results - Bluetooth adapter not available emsyr 1 1,445 08-29-2022, 02:46 PM
Last Post: emsyr
  Why not Atheros ath9k_htc for wifi? altulke 13 6,885 08-11-2022, 01:01 PM
Last Post: auanta
  Did i break my wifi with the keyboard? captchasolver 5 3,281 02-10-2022, 03:39 PM
Last Post: pothos
  Suddenly WiFi signal strength is poor cinix 4 3,599 09-26-2021, 04:19 PM
Last Post: cinix
  computer doesn't recognize pinephone for OS flashing Xzska-collab 3 4,216 06-29-2021, 09:37 AM
Last Post: Xzska-collab
  Wifi/BT interface not detected aithal 17 15,092 05-30-2021, 11:10 AM
Last Post: Krasimir
  WIFI not available after anx7688 update failure frimmel 21 19,882 05-11-2021, 02:45 AM
Last Post: frimmel
